Another hard start thread(I've replaced or checked everything I could think of)
So my car runs fine and starts fine for the rest of the day after the initial start in the mroning after i leave it overnight. It takes at least 10 cranks then it sputters a bit then starts. I've replaced the plugs, plug wires, rotor, ignition coil, fuel filter and have checked the main relay, fast idle valve and the water temp sensor seems good as I don't throw any codes. I'm out of ideas and could use some expertise.
edit- the only thing I can think of now is that I lose pressure from my fuel lines overnight.........I prime my lines before I start but do so only once.
Connorjaymes
10
May 12, 2018 07:28 PM
teg racer 877
Apr 7, 2010 09:53 PM
sohcVTEK
Jun 18, 2006 08:44 PM
X2BOARD
Jul 25, 2002 09:04 AM
