y7/y8 minime timing problem... searched, trial and error. please help
breifing:
its a 93 delsol with a 96 d16y7 block stock internals, and a 96 d16y8 head stock internals. i cant get the timing right to save my life.
im using a d16z6 timing belt and i dont have ANY of the timing covers. the crank pulley bolt will not break for anything and i know these things are just a pain in the *** ive broken loose atleast 10 different ones. ive read all the timing posts, the y7 mini me posts and stuff like that. searched for mini-me, minime, y7 minime, d16y7 minime, timing, how to time, 16 BTDC, SOHC timing, D16y7 stock timing, and read all the timing stuff i can including the timing belt replacement topic by poison i believe and all the minime stuff.
questions:
is their anyone out there that knows of some way to set the engine to TDC with out removing the crankpulley (since i cant)... or without using the timing covers.
ive even tried setting it by the crank sprocket using a mirror to line the knotch up with the oil pumps arrow but i cant even get that right.
i need to know do i set the car to TDC then adjust it to 16 BDTC after i get it running or do i set it to 16BTDC from the beginning.
questions:
nope, the only way to do it is to look at the cam gear and the crank pointer behind the crank pulley (or atleast thats how i did it). to get the crank pulley off, try heating up the crank pulley nut with a torch. it works a lot easier that way. and if you have your flywheel still in. use something to hold the flywheel like a big *** screw driver or a flywheel holder that they make. goodluck, its a PITA.
bump anyone know where i can get a picture of the d16y7 outer bottom timing cover then so i can get closer to where the lines are supposed to be lined up at and use a timing gun
nuclidex
Jul 22, 2014 02:03 AM
builtsinglecam
Oct 3, 2011 03:59 PM
