b20 block, gsr head, what injectors?
Old Jun 14, 2005 | 07:12 PM
getnasty's Avatar
Default b20 block, gsr head, what injectors?
well i got the car. and the kid I got the car from says he dosent know if they are ls or crx si injectors in the car.. what to use? im running the stock si harness if that matters.. also I need to know the injector wire colors for each cylinder. I pulled the harness and didnt pay attention so if you could just check so I dont get it wrong.. like starting from the pass side over? thanks
Old Jun 14, 2005 | 07:49 PM
getnasty's Avatar
Default Re: b20 block, gsr head, what injectors? (bottle fed)
anyone?
Old Jun 14, 2005 | 07:56 PM
crxnj's Avatar
You say the it has the stock si harness so it should have a resistor box..So as long as the injectors are peak and hold it doesnt matter which ones you use..
And they're both the same size..(I think like 270cc)
Old Jun 14, 2005 | 08:00 PM
getnasty's Avatar
Default Re: b20 block, gsr head, what injectors? (Mr.speaker)
yeah im using teh resistor pack. so even stock si injectors will work fine?
Old Jun 14, 2005 | 08:20 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">yeah im using teh resistor pack. so even stock si injectors will work fine?</TD></TR></TABLE>
Yup..
tyvtec23
Nov 11, 2011 05:37 PM
itr-mugen
Mar 18, 2007 02:43 PM
89 pos
Mar 18, 2005 07:31 PM
XzzYzzX
May 17, 2003 05:22 PM
TurbodCX
Feb 14, 2002 10:26 AM
