d16y7 into 89 si
Old Jun 14, 2005 | 07:04 PM
90LSpimpin's Avatar
Default d16y7 into 89 si
Sup folks. I'm finishin up a swap for a customer. Got everything in, just wonderin what i need to do for the radiator fan. On the a6, the switch is on the back of the block, and on the y7 its on the thermostat housing. Wonderin how i should wire it up so that the fan will work as normal, or if i should just wire it up to a constant? Thanks!
Old Jun 14, 2005 | 07:19 PM
CRseXy's Avatar
Default Re: d16y7 into 89 si (89SiPimpin)
on the y7 is it just 2 prongs?? if so, It just a simple thermal switch, just wire the 2 prongs onto the 2 prongs on the y7. simple.
Its a simple switch really. its either FULLY on, or FULLY off. all it does it finish the circuit.
Old Jun 14, 2005 | 07:20 PM
90LSpimpin's Avatar
Default Re: d16y7 into 89 si (pogiTSI)
Thats what i thought, but i was readin that if i tried to do that it wouldnt work. I'll try that first, and see what happens.
Old Jun 14, 2005 | 07:21 PM
FalkenSiR's Avatar
https://honda-tech.com/zerothread?id=1247078
Dee9222
Mar 18, 2014 01:34 AM
91hatchproject
Feb 1, 2010 03:14 PM
bignosewhipper
Jun 22, 2008 08:46 PM
slowassciv33
Sep 26, 2005 03:11 PM
4DRmafia
10
Jun 20, 2004 10:49 PM
