help with block girdle in a b20b
Old Feb 11, 2002 | 07:27 AM
rolow's Avatar
Default help with block girdle in a b20b
Do I need one?
Keep in mine this motor is fully assembled an in the car
If i do need one should i use a gsr or z10?
My car has a b16 oil pan!
I also have a z10 girdle (not instaled) the guy who built my motor said the one time he had used the Z10 he could not get an accurate torque reading because
the aluminum was to soft? Thats why he did not instal mine?
is this fact or bull#$%t?
He also said it might loosen up?
fact or bull again?
If you guy recomend the gsr girdle what parts do i need ?
part #'s and prices you have paied ?
Old Feb 11, 2002 | 07:30 AM
Spade's Avatar
Default Re: help with block girdle in a b20b (rolow)
Basically you need everything below the main bolts on the GSR.
oil pan, oil pickup, girdle.......this has been discussed before, if you do a search you will find many ways to do this.
Old Feb 11, 2002 | 08:05 AM
rolow's Avatar
Default Re: help with block girdle in a b20b (Spade)
what all will i need if i use the z10 girdle?
ShortbusEK
Apr 20, 2008 12:00 PM
mchuang
Mar 31, 2004 05:58 PM
LBR92DA-T
Dec 20, 2003 02:23 AM
Combustion Contraption
Sep 3, 2003 01:04 PM
built562
May 11, 2003 06:39 PM
