Bombing the spiders out of my car
Old Jun 14, 2005 | 06:38 PM
Keith P's Avatar
Default Bombing the spiders out of my car
So I've been working on my old EF again (after a 3-4 year break). It seem a bunch of different arachnid species have decided to camp in my car. I ended up with a bad spider bite. I have to take anti biotics and it itches like all hell.
How can I safely and cleanly evict my unwanted tenants? This bite is traumatizing me. I'm scared to work on my car again.
Old Jun 14, 2005 | 06:42 PM
rexerin's Avatar
yikes, i'd be traumatized too! i hate those buggers. i'm not sure if they work cuz i haven't tried them yet, but those plug-in pest repeller things are supposed to send spiders, mice, etc away. extension cord and a couple bucks at Target would be worth a try... meets your "safe and clean" requirements. otherwise it's RAID all over your interior...
good luck!
Old Jun 14, 2005 | 06:44 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Bombing the spiders out of my car (Keith P)
put on a long shirt and pants or a garage suit and keep a fly swatter on hand and kill those bishes
Old Jun 14, 2005 | 06:49 PM
Bjorn20's Avatar
Default Re: Bombing the spiders out of my car (floss)
that will get hot as hell though
Old Jun 14, 2005 | 06:54 PM
kurinto's Avatar
I say long sleeves and a vacuum, start pulling the interior out and clean everything. Put a blowgun on an air compressor and blow out all the nooks and crannies.
Old Jun 14, 2005 | 07:04 PM
bspeed's Avatar
I would go get a tank of CO2 (5-10lb bottle) from a welding supply place, remove your driver or pass seat to have a nice flat surface, set your climate control to outside air (to release pressure), put the bottle in a cardboard box standing up straight, crack the valve and shut and LOCK the doors, leave it overnight, nite nite spideys.
Why this method is awesome;
-No Odor
-No Residue
-NON-TOXIC (provided you aren't in the car)
-Spiders cannot breathe in a CO2 saturated environment nor can the eggs mature.
-Spiders don't dig the cold, this is going to create carbon dioxide frost.
Things you have to consider;
-If you do this in a garage ensure it is locked and/or very thoroughly ventilated (wouldn't want to suffocate your self or the kiddies)
-This is going to make your car very cold, and if it is hot in your neck 'o' the woods you can get condensation. Condensation=bad for unpainted steel and unsealed electronics (your dash support and ecu/wiring/stereo) So keep it covered or in a garage/shed.
Old Jun 14, 2005 | 07:13 PM
Keith P's Avatar
Default Re: Bombing the spiders out of my car (bspeed)
I guess most of you have never seen my HB.. It's 90% stripped. I have no climate control. It's 2 seats, a cage, dash & door panels. The interior is sprayed with a truck bed liner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bspeed &raquo;</TD></TR><TR><TD CLASS="quote">I would go get a tank of CO2 (5-10lb bottle) from a welding supply place, remove your driver or pass seat to have a nice flat surface, set your climate control to outside air (to release pressure), put the bottle in a cardboard box standing up straight, crack the valve and shut and LOCK the doors, leave it overnight, nite nite spideys.</TD></TR></TABLE>
I actually have a 15lbs co2 bottle. I use it to run my air tools. Works great when off roading, at the track, etc..
Will they die? what about babies? I see white nests in every crack.
I like working on the engine better
Old Jun 14, 2005 | 07:18 PM
EFbomb's Avatar
close up the car and release a bunch of wasps ... wasps kill spiders
Old Jun 14, 2005 | 07:28 PM
mr. carpenter's Avatar
Default Re: Bombing the spiders out of my car (EFbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFbomb &raquo;</TD></TR><TR><TD CLASS="quote">close up the car and release a bunch of wasps ... wasps kill spiders</TD></TR></TABLE>
then you could release some japanese hornets to kill the wasps. what kills japenese hornets?
Old Jun 14, 2005 | 07:39 PM
Sequoyah's Avatar
Default Re: Bombing the spiders out of my car (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">
then you could release some japanese hornets to kill the wasps. what kills japenese hornets?</TD></TR></TABLE>
LOL! I think a good ol' can of wasp and hornet spray should do the trick
Above, you have all of the steps to eradicate the spiders from your car and also the Giant hornets...do a write up and let us know how it goes
Old Jun 14, 2005 | 07:42 PM
TheSSG's Avatar
I had the same issue.
Live and let live is my philosophy. They'll all move out once the thing starts getting used...
Turn on the engine and let it idle a bit if you can, the vibrations annoy them.
Otherwise, be careful.
Old Jun 14, 2005 | 07:50 PM
DreamCatcher's Avatar
I once had a sentra with ants...... Remove your seats, gut the car of all hiding places, liberally spray bug spray, let it sit for a day, wash the interior with a mild bleach solution, and patch any holes leading into your car, also, clean under the hood.
Old Jun 14, 2005 | 08:00 PM
EFbomb's Avatar
Make sure its not a brown reclouse...check this out
Im so paranoid of these damn spiders its not funny
http://www.surviveoutdoors.com...e.asp
Old Jun 14, 2005 | 08:15 PM
AE86man's Avatar
Default Re: (EFbomb)
HOLY MOTHER OF GOD!!!!!!!!!
That guy's leg looks like he got shot or something!!!!!!!!!!!!!!!!!!!!!!!
And I'm arachnaphobic to begin with and now I'm even MORE paranoid of those eight-legged little bastards...............
Old Jun 14, 2005 | 09:56 PM
ServiceAdvisor's Avatar
Had one bite me on the face. Looked like someone put out a cig on my cheek. Took some antibiotics and it went away in a week or so. You can't even notice the scar and I have great skin. We all expected to see a huge hole or something. Just don't let it go for long periods w/o antibiotics or end up like those puds.
I wouldn't recommend bombing since it might stay in the ducts of your ac/heat and the seats foam material. Just not healthy and whatnot. I like the C02 idea, but I'd be scared of it getting too cold and cracking windows or destroying something even if the car is gutted. Just put on some work gloves and strip it to the max, then get the hose out and spray it out. The air compressor idea seems the most feasible.
Old Jun 14, 2005 | 10:07 PM
explictness's Avatar
Default Re: (AE86man)
How come that didnt happen to spider-Man when he was bitten by that spider, he got ****** swole and spider powers instead of being poisoned and shizz. -=P
Old Jun 15, 2005 | 02:34 PM
bspeed's Avatar
Default Re: (DOHCZCCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">. I like the C02 idea, but I'd be scared of it getting too cold and cracking windows or destroying something even if the car is gutted.</TD></TR></TABLE>
It won't get THAT cold.
It will kill everything that is alive in your car with the doors shut. Between the cold temp (maybe 20-30F at night like a cold refrigerator). This is how my friends and I have cleaned out old boats, cars, even did it to an attic of a house we were working on.
If your car is that gutted down you could get one of those bug bombs that leave no residue. I like and use the CO2 because I think it is a little more safe and def way more fun.
Old Jun 15, 2005 | 03:17 PM
Keith P's Avatar
Default Re: (bspeed)
It's pretty empty
I'm going to BOMB it!
Old Jun 15, 2005 | 03:30 PM
SlobberGoat's Avatar
Default Re: (Keith P)
Just make sure that you do a COMBAT ROLL just before you throw the spray bomb, so the spiders will have less chance of detecting your attack.
Old Jun 15, 2005 | 05:09 PM
kurinto's Avatar
Default Re: (explictness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness &raquo;</TD></TR><TR><TD CLASS="quote">How come that didnt happen to spider-Man when he was bitten by that spider, he got ****** swole and spider powers instead of being poisoned and shizz. -=P</TD></TR></TABLE>
Because it was radioactive.......duh.
Old Jun 15, 2005 | 06:16 PM
SwissChEz82's Avatar
Default Re: (SlobberGoat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlobberGoat &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure that you do a COMBAT ROLL...</TD></TR></TABLE>
That's awesome, gotta do the combat roll.
Old Jun 15, 2005 | 07:46 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (SwissChEz82)
lol. I have a mud dauber nest inside my drivers side rearview mirror. how can i get rid of them? not enough room to put bee spray in it. And vtec doesnt seem to scare them off.
Old Jun 15, 2005 | 10:40 PM
bspeed's Avatar
Default Re: (EFB16ACRX)
get a friend to blow ciggarette smoke in there.
Old Jun 15, 2005 | 10:49 PM
NastyHabitzCRX's Avatar
when my accord was down and out for months, i used ordinary airfresher lemon or citrus scented and cranked on the fan. most insects will leave since the citric acid is irritating to them, plus your car smells ok.
Old Jun 15, 2005 | 10:52 PM
blahhhhhhhh's Avatar
dont forget to yell fire in the hole
