how can you tell if you got a reg b16 head from a type r head?
Old Jun 14, 2005 | 05:38 PM
aser1z's Avatar
Default how can you tell if you got a reg b16 head from a type r head?
what marks mean which head?
pr3-_=b16 or type r
Old Jun 14, 2005 | 05:56 PM
JV's Avatar
JV
Who?
Default Re: how can you tell if you got a reg b16 head from a type r head? (aser1z)
Both are stamped PR3. Cams, valvetrain, and intake ports are the main differences...
Do a search for "ITR / B16 head" or something. Lots of info in the archives.
Old Jun 14, 2005 | 06:51 PM
Kendall's Avatar
Look into the ports. If it looks all nice and smooth after the valves then it's an ITR head. Other identifying features include green paint next to the dizzy area, but that wears off eventually.
Old Jun 14, 2005 | 07:07 PM
jdmsiR20's Avatar
Default Re: (Kendall)
also, green paint on valvesprings... again, somewhat easy to remove/replace
Old Jun 19, 2005 | 11:18 AM
JDM99Hatch's Avatar
all you need to do is check the valve springs, are the intakes and the exhaust both dual springs, and if there is no valvetrain , look into the the intake bowls they should look like they are mildly ported. Intake valves are also tulip shaped. No real big advantage with buyin that head, your better off gettin a bear b16 head and getttin good vavles and spring/retainers, price wise they are about the same if you add all that work.
porofek
Apr 12, 2019 08:58 AM
Jacob Downes
Apr 26, 2018 07:45 PM
SmoKez
May 10, 2012 08:56 AM
12secdc2
May 11, 2009 12:44 AM
ramtyper19
Oct 5, 2005 08:09 PM
