MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN TO
Old Jun 14, 2005 | 05:01 PM
95civickid's Avatar
Default MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN TO
MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN TO COME ON OR OF THE EF SENSOR HAS TO PRAWNS ON THE SENSOR TO TELL IT TO TURN ON AND OF I NEED TO NO BECUASE I DID A 99 CONVERTION ON THE EF AND IM USEING A 92-95 RADIATOR AND THE FAN DOESNT WORK THE ONLY WAY FOR IT TO WORK IT TO GROUND IT BUT IF I DO THAT IT WILL STAY ON ALL THE TIME
Old Jun 14, 2005 | 06:19 PM
civic_tuner's Avatar
Default Re: MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN
bump, cause I want to know too.
Old Jun 14, 2005 | 08:09 PM
.Smitty.'s Avatar
Bump. Someone give this man an answer.
Old Jun 14, 2005 | 08:14 PM
D15Bbigred's Avatar
hook it up too a switch, its not hard to remember to turn it off....
Old Jun 14, 2005 | 08:19 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (EG1racer)
turn the caps off man
try to hook the power up to a wire or something that just turns on when when the ignition is on
Old Jun 14, 2005 | 08:39 PM
nocturnaldragon's Avatar
LOOK!
You were warned already about creating similer threads asking the same question. TAKE A HINT AND KNOCK IT OFF!
Also the caps **** a lot of people off me being one of them!
REPORTED!
Old Jun 14, 2005 | 08:57 PM
dantastic's Avatar
just buy a new thermoswitch (one that fits the old obd-0 style thermoswitch plug you're describing). or you can buy a pigtale plug that fits the thermoswitch on the b16a2.
Old Jun 15, 2005 | 12:11 AM
built562's Avatar
Default Re: (dantastic)
you can get a thermaostat switch kit they sell at like autozone and pepboys. i forgot what its called but it comes with a sensor and all the wiring and it works independantly and will turn on ur fan at a certain temp. so you dont have to wire it strait to a switch.
rstewart4328
Jan 26, 2017 03:06 AM
Jay Jackson
12
Apr 14, 2013 09:17 PM
Homicide
Jul 1, 2006 07:23 AM
95civickid
Jun 14, 2005 04:42 PM
jdmEFsedan
16
Apr 7, 2005 08:07 AM
