1g eclipse - no spark, help? anyone?
Old Jun 14, 2005 | 04:51 PM
spettinger's Avatar
Default 1g eclipse - no spark, help? anyone?
coils seem to test the same as a new one.
replaced the crankshaft position sensor after reading code 22 from the diagnostic plug.
replaced the power transistor module that is under the coil packs.
can anyone suggest anything else to check? thanks
Old Jun 14, 2005 | 05:09 PM
slomofo's Avatar
GDD Member
Check power to the coil pack, look for the ignitor and test it too. Also test output state of cam position sensor, it's on passenger side at the end of the intake cam..
Old Jun 16, 2005 | 08:07 AM
spettinger's Avatar
Default Re: (slomofo)
i do have ignition power going into all the plugs, at the cam sensor, power transistor, coil pack.
how do you test the output state of the cam sensor?
Old Jul 15, 2005 | 03:09 PM
psi2high's Avatar
make sure your ecu isnt fried
mushmash
May 21, 2018 08:05 PM
martpav
Honda Civic (2001 - 2005)
Aug 18, 2013 07:22 AM
phj
15
Jun 16, 2011 04:43 PM
kaanghu
Jun 13, 2011 07:01 PM
BoostedH23a1
Mar 21, 2003 01:09 PM
