JUN STROKER MOTOR ISSUSES
I have a Jun Type R stroker motor in my car. My problem is that the last counterweight on the number 4 cylinder broke. So I have a broken Crank. I need a new one. Where can I go to get one? I talked to Jun Japan and they told me that they can not sell the crank alone. i need to buy the entire kit. which sucks cuz it is $3600.
I also need a new clutch disc if anyone has one of those. I was useing the Jun 3 puck, and I would like to get another.
Thanks.
Thanks.
Gotta love that Jun customer service
Like someone else said, Crower or Eagle should be able to hook you up with a replacement crank; it won't cost $3600 either
94 mm crank. that's gonna be custom. still, less then 3600.
whats your r/s ratio???
no deckplate or anything, means low r/s ratio.
hmmmz. were does the engine peak?
i meant where does the power/torque peaks. taking a 89mm crank in combination with a long rod and custom piston can give you good r/s ratio. but with 94 mm you don't have much room to play with. top of line with 95 mm champs mostly run deckplates to run good r/s ratio. that's why i was curious about your engine character.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">I can help you with a custom crank.</TD></TR></TABLE>
Yeah, but can't they just do an offset grind on a 95mm forged core, that would be a lot cheaper than a billet crank i think. As he's using a 94mm stroke I'm sure Crower could make him a replacement. And I must say, the quality of the forged Crower cranks are very good, I have a 92mm myself, got it from Rocket.
All jun internals.
I want to know what I need to know so that I can get one of the crower cranks on order. what do I measure so that I dont mess up and get one I dont need. Thanks.
I dont know. I bought this car from a friend. I have been into watching cars, and being a wrench bitch on 4 DSM motor swaps, but this is the first honda motor that I have pulled. So, I dont know much, but the guy that I was a wrench bitch for is the best at working on DSM's in Iowa. So, any questions that you have that I dont know I will ask him. I just need to know what to ask.
This is the first time that the motor has been taken outta this car since it was put in two years ago. It was installed by jun USA in Cali. I was told that it was a stage 4. That would make it a 2.0, but I dont know if it is for sure. I would ask the person that bought the motor, but he is currenttly unreachable for the next 2-4years. So you can see how is just gets to be a larger pain in the *** with each moment.
thanks for everyone that is trying to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Broken1 »</TD></TR><TR><TD CLASS="quote">All jun internals.
I want to know what I need to know so that I can get one of the crower cranks on order. what do I measure so that I dont mess up and get one I dont need. Thanks.</TD></TR></TABLE>
def call Brian Crower @ Crower and ask him!! He's great...
Well, I found out today at the machine shop that the Crank journal is fucked. If it machined it will mess with the center line of the crank too much. So, I have a few options, I can buy a new B16B block (and a crank for a stroker Motor(Crower)) the Rods and pistons are ok and then I can throw the head on the new block and use the old tranny and drive it until the motor takes a **** again...
Or I can just throw the block away and sell the Full Jun Race head w/ cams and sell the rods and pistons. Then sell the tranny since that is ok. Sell the suspension and everything outta it and just put it back to stock and trade it in on a SUV.
What do you guys think. Everything on the car can be sold except the block. Everything is fine.
