really weird idle problem..help
ok guys, I have an idle problem. I let the car sit there and it idles fine. When I shift the car from any gear (automatic) it's fine but when I put the car back in either neutral or park the idle starts to jump up and down. When I turned on my lights, the idle stopped and was fine even after i turned off the lights, the idle is fine. But! as when I press the brakes the idle starts to jump again. I'm thinkin it has to do with my brakes maybe the bb? Because right now my brakes are fucked. I'd have to push in the brake pedal more farther for the car to stop. What do you guys think?
diy on the bb. on a side note, my auto lebaron does almost the same thing, cept it revs totally on its own to about 2k, then comes down to 1k when i hit the brakes in neutral. if i leave it in drive and hit the brakes i can feel the car trying to take off. its wierd and i've basicly disassembled the entire engine and transmission and nothing has helped.... so get ahold of me if you figure it out
TurboSI24
Nov 23, 2005 03:39 PM
