high rpm sudden power loss
just thought i'd post my question here too and see if i can get any more suggestions. basically, the engine abruptly cuts off at around 7,000 rpm (accord - h22a - 5 speed) in 2nd/3rd/4th gear. it doesn't happen in neutral or 1st, so i know it can't be a rev limiter (not to mention i'm running a chipped ecu with a raised rev limiter). but whenever i give it throttle in any of those mentioned gears and reach 6.5 or 7k... the tach needle starts getting a bit jumpy and then BAM.. it just feels like i hit a wall or something.. there's a loud sound and the car jerks... the revs drop for a split second.. and then all of a sudden i regain control again.. and the car drives normally.
i've tried switching ecus and it happens with the stock p13 as well as the p28 chip. i was thinking it could be ignition related (timing, etc.), but wouldn't the problem happen throughout the whole entire powerband then? i mean, it will drive normally unless i take it up into the high 6k range.
most people i trust are telling me this is probably something electrical.. but nobody has any idea as to what exactly.
any suggestions will be helpful of course.
Modified by accordtunerx at 1:36 AM 6/15/2005
pkprelude
May 8, 2003 07:58 PM
pkprelude
May 8, 2003 04:48 PM
