SPARCO SEATS - Starting to make alot of sounds..
my passenger side was making alot of creaking, now my drivers.. its mainly gonig over bumps and stuff.. sounds like an old sofa... anyone else have this problem??? im gona lube up the main points with WD-40.. anyone else recommend anything?
and no im not fat for all the smartasses out there lookn for a shot = P
My Sparco seats were making an annoying rattle noise at certain RPMs and when going over bumps - turns out it was the spring/wire that runs under the seat bottom. Taped it up and no problems since...
"you should probably just sell the car if your seats are making noise"
Har har, you made a funny. Pat yourself on the back, pick the booger outta your nose and enjoy your dinner.
"My Sparco seats were making an annoying rattle noise at certain RPMs and when going over bumps - turns out it was the spring/wire that runs under the seat bottom. Taped it up and no problems since... "
when im cruisin in the city and going over bumpy roads then it starts screeching like an old'sofa, i think the wd-40 may help
I've got random creaking from my driver side seat sometimes, usually when I first sit down... no "old sofa sounds" while driving though. I used to have a little bit of a rattle on my passenger side, but it went away when I took the seat out to install something and put it back in (shrug)...
I'm convinced it's the sparco rails... dunno.
I had a chirping sound that was coming from my seat belt recepticle (the thing with the button).
Cracked it open and greased the spring slightly.
I gota laugh when people install a race part in their street car and then complain about things like squeaks.
<------------wears earplugs on long trips.
I know, purpose built race parts just don't have the engineering or durability of street parts.
I love it when a racer talks of "race engineered" parts like they're "better" than street parts. Okay, it's purpose built, so it does one thing better, but the engineering stops there - nothing about street durability (precision, etc.) is put into the part because it's not needed.
Uh, well you figure you pay half a g note for a seat it won't squeek?... car is all dolled up, waxed, mint interior got a passenger admiring your car and all the sudden just 'pfshh fpshh fpshh' lol...
you guys are too serious about things = )
FWIW, my sparco corsa passenger seat creaks often.
I don't think wd40 in the bolt will help, actually that's the last bolt i'd want to lube.
Try to spray the area between the seat and the seat mounts themselves...
[edit- in response to the above post, the were not designed to be squeak-free show-off seats, they cost 650 because they are SAFE!]
apexxi: when sittin in the seat and forcing your back backwards/as it rocks it squeeks..
I'm pretty sure its that , like you said.. but then again i dont know what to use on it.. My seats are black (so im not worried about staining) but i dont want to spray wd-40 on my seats and getting mhy clothes dirty lol
