Balancer shaft yes or no question????????
Old Jun 14, 2005 | 08:49 AM
SPEEDQUEST INC.'s Avatar
Default Balancer shaft yes or no question????????
I did some search but I need to confirm this with someone who's actually done it. Will it **** something up if I remove just the belt and not the actual shafts? The motor is in an EK and I have Hasport mounts. The actual engine is an H23 with type s pistons and h22 head, manual tensioner. I'm about to install the timing belt and I need to know soon and I really need to know if it's ok to leave the balancer shaft belt off. Thanks in advance...
Old Jun 14, 2005 | 08:58 AM
DR's Avatar
DR
Default Re: Balancer shaft yes or no question???????? (SkunkEk)
It will not mess anything up if you just remove the belt. It gains you about 3hp.
Old Jun 14, 2005 | 09:02 AM
johnny five's Avatar
it will be fine you'll just have some vibration, there is a dyno in the FAQ and kaizenspeed.com makes a balancer shaft eliminator kit.
Old Jun 14, 2005 | 09:09 AM
Default Re: Balancer shaft yes or no question???????? (DR)
Thanks a lot sir, thats all I wanted to know... Maybe in the future i will do the elimination kit, but i have to get my car off the lift now, and I wanted know if it was ok to leave the shafts on without the belt.... thanks again!!
Old Jun 14, 2005 | 09:11 AM
cpforyou's Avatar
Removed belt for over 1.5 years. No problems yet.
Old Jun 14, 2005 | 09:33 AM
Default Re: Balancer shaft yes or no question???????? (cpforyou)
sweet.. thank all you guys
Old Jun 14, 2005 | 09:36 AM
skunked's Avatar
<-----What balance shaft belt
Old Jun 14, 2005 | 05:47 PM
Cashis Lee's Avatar
Default Re: Balancer shaft yes or no question???????? (skunked)
I have mine removed for a couple months now. Vibrations are only noticeable the first 2 days I got the car back. Afterwards, unnoticeable vibrations. No problems whatsoever.
Old Jun 14, 2005 | 05:48 PM
xludexgenx5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-----What balance shaft belt </TD></TR></TABLE>
same here. over a year of the race track and no issues yet...
Old Jun 14, 2005 | 06:03 PM
john d
Guest
Posts: n/a
Default Re: Balancer shaft yes or no question???????? (xludexgenx5)
there is a member on here that sells them for $20 shipped, way better than $82 shipped. ive had mine for a while, IMO its not worth doing unless you have a "full race" set up
unlike skunked, hes a ricer
Old Jun 14, 2005 | 07:17 PM
H_doubledeuce_A1's Avatar
Have been running without a balancer belt for about a year or so, no problems what so ever. You'll notice your H22a1 accelerate a little faster.
Old Jun 14, 2005 | 07:41 PM
damonk's Avatar
Default Re: Balancer shaft yes or no question???????? (H_doubledeuce_A1)
Is the belt something easy enough to cut yourself? i've been thinking about this for a while.
Old Jun 14, 2005 | 07:56 PM
xbn83's Avatar
Not worth the risk if you daily drive your car.
Old Jun 14, 2005 | 08:18 PM
prelude1897's Avatar
I have this done along with doing a manual tennisor conversion, and everything works just fine
Old Jun 14, 2005 | 08:41 PM
Innovation's Avatar
Default Re: Balancer shaft yes or no question???????? (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Not worth the risk if you daily drive your car.</TD></TR></TABLE>
Really? Why's that?
Old Jun 14, 2005 | 09:57 PM
Hawkze_2.3's Avatar
What risk?? The risk of spilling your coffee??
Removing the balance shafts does not hurt the engine, it just causes more vibration.
Old Jun 14, 2005 | 10:44 PM
jaxx4k's Avatar
i took it off my build h22...rather keep the shaft spinning it just sit in side... i havent heard anything bout being bad for the bottom end.. so im guessin is good...
im boosted for 4000 miles n no problem w/it off...
Old Jun 15, 2005 | 07:51 AM
skunked's Avatar
Default Re: Balancer shaft yes or no question???????? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">there is a member on here that sells them for $20 shipped, way better than $82 shipped. ive had mine for a while, IMO its not worth doing unless you have a "full race" set up
unlike skunked, hes a ricer </TD></TR></TABLE>
The block I'm building has the balance shaft eliminator kit in it.
And yes I am a ricer
Old Jun 15, 2005 | 09:21 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkEk &raquo;</TD></TR><TR><TD CLASS="quote">The motor is in an EK and I have Hasport mounts. The actual engine is an H23 with type s pistons and h22 head, manual tensioner. </TD></TR></TABLE>
I bet that will be a fun car to drive...
Old Jun 15, 2005 | 12:04 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
can the shafts come out with the motor in the car?
Old Jun 15, 2005 | 12:47 PM
skunked's Avatar
Default Re: Balancer shaft yes or no question???????? (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">can the shafts come out with the motor in the car?</TD></TR></TABLE>
I don't think so. There is more work than just the removal of shafts needed such as blocking the oil passages.
Old Jun 21, 2005 | 10:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">
I bet that will be a fun car to drive...</TD></TR></TABLE>
Yes it is... I would like to thank you guys for the help, I removed the belt and the car doesn't vibrate any different than what it used to, It feels the same.
I went to the track and My best time was 12.162 @115.7mph, with a slipping clutch. I hope to go 11's soon
Old Jun 21, 2005 | 10:30 PM
SKDRCR's Avatar
You guys are tempting me to grab a 10mm and some scissors
So the the motor won't have any oil pressure issues if you leave
the shafts in and just cut the belt?
Old Jun 22, 2005 | 11:22 AM
h8trix's Avatar
Default Re: Balancer shaft yes or no question???????? (johnny five)
I have seen motor mount dampers and similar things to absorb vibrations and rocking from the engine. If vibrations did occur from balancer belt removal would it be something curable using some sort of modifcation on the mounts or damper?
http://www.prostreetonline.com...mpers/
From what I understand that is used for launches. I don't really know how bad the balancer belt removal is, I was just wondering if there is a something to cure the issue in the event I choose to go this route. (I have an almost chipped crank pulley on my new engine, I was going to underdrive when I get more funds to afford the new pulleys and maybe look into removing the balancer belt and associated shafts - so I am just doing research for the future... yes I would do this now while the engine is out, but I have done too many mods on the engine as it is and don't have the funds, need my engine in so I can go back to work )
Old Jun 22, 2005 | 01:03 PM
skunked's Avatar
I went to the track and My best time was 12.162 @115.7mph, with a slipping clutch. I hope to go 11's soon</TD></TR></TABLE>
Bitch'n MPH
lude512
May 28, 2013 06:30 PM
Murkin_lude
Apr 5, 2012 03:03 PM
SkylineKin
Aug 23, 2009 07:04 PM
pcguy760
Jun 8, 2006 12:13 AM
brandond
Feb 27, 2005 09:26 AM
