what to do with a jdm b16head on a usdm 2000 gsr block
i am honetly having problems deciding wich way to go on the preformance options for my car witht he current set up that i have right now. i have a jdm b16 head with a usdm gsr block so yes i know i am running high compression out the wazooo. i havent decided wether to go witha turbo at 7lbs or a super charger. the only i ask is help wich way do i go on this one. all i want is to pul the most horse power out of the car and domminte as a gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsandsilver26 »</TD></TR><TR><TD CLASS="quote">i am honetly having problems deciding wich way to go on the preformance options for my car witht he current set up that i have right now. i have a jdm b16 head with a usdm gsr block so yes i know i am running high compression out the wazooo. i havent decided wether to go witha turbo at 7lbs or a super charger. the only i ask is help wich way do i go on this one. all i want is to pul the most horse power out of the car and domminte as a gsr. </TD></TR></TABLE>
you actually lowered compression by doing this. i would boost it if i were you. check out the fi forums and youll find all the info you need to boost your car
