Omni Power Quicklutch master cylinder upgrade - better shifting !!
Here is a product that promises a lot.
Any one used it before or anything like it ?
Is there a OEM Honda alternative ?
Here is what they are saying about it:
The Omni-Power Quicklutch master cylinder has been designed to reduce clutch pedal travel for faster shifts and improved clutch feel. It uses a larger diameter piston which moves the same volume of fluid but with less travel. Used by many top winning racing teams across the world this master cylinder greatly increases shift times by cutting the clutch pedal travel in half.
After you install a short throw shifter your timing will be off from your hands to your feet. This inturn causes mis-shifts and accelerated wear on the tranny syncronizers. With the Omni-Power Quicklutch unit you will restore your shifting synchronization and be able to make more consistent and faster shifts. The majority of users have stated that its the closest thing you can get to a sequential transmission.
Benefits:
Faster Shifting
Adjustable clutch release point
Longer syncro life.
5 year warranty
Faster recovery when gears are missed
Increases clutch feel and crispness
Restores the harmonious synchronization between the short shifter and the clutch pedal.
Note: This item will add to pedal stiffness
Applications it will fit:
92-95 Honda Civic (EG)
96-00 Honda Civic (EK)
94-01 Acura Integra (DC)
If this is for real "I gots to gets me one of these !"
They are sold at http://www.RobearRacing.com, http://www.InlineFour.com and http://www.Kteller.com for those interested.
Let's get some feedback guys.
Thanks
Benefits:
Faster Shifting
Longer syncro life.
5 year warranty
Thanks
Search. There are a couple of really good threads on this product already. Apparently it's damn good. There is no OEM alternative though, but it shouldn't matter as Omniman doesn't half-*** his stuff.
prostreetonline
11
Aug 11, 2005 05:55 PM
