b18b
Whats up guys,
I was wondering would a b18b ls motor swap into a del sol pretty easy? From what i read i think i would use the ls mounts, axle, and ecu but use my d16z's harness? any clue? I read up on alot of **** but I couldnt fine to much on the del sol swaps.
The swap should not be that difficult, it's been done often enough.
I searched for "del sol swap", selected archives, and came up with 5+ pages of info. Try looking through there and see what you can find.
All in all, it should be pretty simple.
both swaps would be about the same amount of work. either way your installing a b-series engine, tranny, cv axles, intermediate shaft, and shifter linkage. Changing your top radiator hose, and possibly some exhaust mods. Your engine is already equiped with vtec wiring so a b16 would be plug and play with stk harness (extending plugs as needed), if you go with b18b the vtec plugs would just hang.
jonathan13
10
Jun 5, 2006 08:44 AM
90civichb
17
Jul 7, 2004 08:56 AM
