GSR motor question
Old Jun 14, 2005 | 01:07 AM
02spoon's Avatar
Default GSR motor question
I have a B18c1 with blown head gasket and
want to rebuilt it . what should i change now that im going to have to open it.
also i have a CTR intake cam what esle should I do . I was thinking minor port work is this a good idea??
Old Jun 14, 2005 | 11:47 AM
ScottyG-Spot's Avatar
Default Re: GSR motor question (02spoon)
i would do some port work and add a spoon or mugen headgasket at the same time and yes add the cams
Old Jun 14, 2005 | 12:26 PM
92Jspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02spoon &raquo;</TD></TR><TR><TD CLASS="quote">I have a B18c1 with blown head gasket and
also i have a CTR intake cam what esle should I do . I was thinking minor port work is this a good idea??</TD></TR></TABLE>
everything you mentioned sounds good. don't forget to get a valve job and maybe even mill the head a little to bump your compression up. what kind of power are you looking to make? is this gonna be your daily driver as well?
Old Jun 14, 2005 | 01:00 PM
02spoon's Avatar
yes a daily driver not crazy power maybe just to pull on a rsx type S
how much should I mill the head.
Old Jun 14, 2005 | 01:37 PM
92Jspec's Avatar
Default Re: (02spoon)
go .030 thousandths and use a stock headgasket. and you're gonna have to advance the intake cam +2 and +2 on the exhaust cam as well. so you're gonna need adj. cam gears.
Old Jun 14, 2005 | 11:07 PM
02spoon's Avatar
thanks guys for all the info
Old Jun 15, 2005 | 01:54 AM
AlLMoToRvOtEr's Avatar
Ya everything sounds good you should mill the head like they said but use a thinner headgasket then OEM. Slap a ITR exuast cam in it and I wouldn't go +2 on the exuast but -1. I had the same setup in a hatch with a GSR motor and lost power advancing the exuast cam........................Maybe a vafc and have someone tune it for you.
Old Jun 15, 2005 | 02:59 PM
92Jspec's Avatar
Default Re: (AlLMoToRvOtEr)
just remember the more you mill the head you have to compensate by advancing the cams. also by using a thinner head gasket you have the chance of valve to piston clearence issues. stick with the stock headgasket and you'll be fine.
Old Jun 15, 2005 | 08:01 PM
Juggernaut 2's Avatar
Explain rebuild it i.e entire motor? Dont waste your time milling the head unless needed (because of warpage), compression will be raised but not enough to notice anything. What are your goals/intentions for the motor?
Old Jun 16, 2005 | 12:52 AM
02spoon's Avatar
Rebuilt = diSENBLE and asemble WITH NEW GASKETS SEAL AND BEARINGS sorry caplocks stuck
Old Jun 16, 2005 | 08:32 AM
If your trying to gain some compression get some usdm itr pistons and slap em in since your replacing the bearings, new rings and cast pistons will run about $250. Those pistons should bring you into the 11's cr, but it all depends on what you want out of the motor just something with a little passing power or a beast.?
Old Jun 17, 2005 | 09:53 AM
92Jspec's Avatar
Default Re: (Juggernaut 2)
well if you plan on tearing the whole engine down to replace eveything, then yeah slap some itr or p30's in the block with a fresh hone. might as well change out the oil/water pump. sorry bro i didn't know you were planning to tear down the whole motor, i thought you were just gonna fix the headgasket and call it a day thats why i said mill the head. but good luck on your re-build bro.
Old Jun 20, 2005 | 12:27 AM
02spoon's Avatar
thanks for all the input, aready started the tear down.
This is my first time dissasembling and assembling a motor
Old Jun 20, 2005 | 10:07 AM
92Jspec's Avatar
get a helms manual as well if you don't already have one. and good luckon your rebuild bro. keep us updated
Old Jun 20, 2005 | 01:05 PM
ptoledo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juggernaut 2 &raquo;</TD></TR><TR><TD CLASS="quote">If your trying to gain some compression get some usdm itr pistons and slap em in since your replacing the bearings, new rings and cast pistons will run about $250. Those pistons should bring you into the 11's cr, but it all depends on what you want out of the motor just something with a little passing power or a beast.?</TD></TR></TABLE>
Im not hating, just wanna clarify USDM ITR pistions in a GSR block w/ a stock GSR head will give you roughly 10.8:1 with a stock head gasket, unless you are also milling the head. I went with PR3 wihich will give me 11.5.1 w/ a stock head gasket.
Like Juggernaut 2 said, it all depends on what you want. Daily driver or Race. With 91 pump gas in CA, I wouldnt go anything past 11.6:1 comp ratio. This is info I got from my builder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Jspec &raquo;</TD></TR><TR><TD CLASS="quote">well if you plan on tearing the whole engine down to replace eveything, then yeah slap some itr or p30's in the block with a fresh hone. might as well change out the oil/water pump. sorry bro i didn't know you were planning to tear down the whole motor, i thought you were just gonna fix the headgasket and call it a day thats why i said mill the head. but good luck on your re-build bro. </TD></TR></TABLE>
You also want to check the condition of the block and see if OS pistons are needed. It would suck to have a fresh hone, install the pistons and experience piston slap.
I myself went with a fully built motor. I made sure I did it right. Spent a **** load of money. If you have any questions, feel free to ask. Good luck with the build.
Old Jun 21, 2005 | 01:12 AM
02spoon's Avatar
well I looking for somthing in the middle DD and Race. I want to be able to at least make the same hp as a B18C type R or maybe a tad bit more .
NO, hold on.
I made up my mind ...
A tad bit more
Old Jun 21, 2005 | 04:39 AM
FastGsr95's Avatar
Default Re: GSR motor question (ScottyG-Spot)
I did a mild port job on my b18c1 and put typre r pistons and a block guard i was happy with it
h2bek
Aug 9, 2010 07:15 PM
Dohcvtec59
Oct 15, 2004 04:44 AM
hondaeg8
11
Aug 26, 2004 02:45 PM
BillB
13
Apr 14, 2004 10:36 AM
bubbajim
Aug 21, 2003 07:26 PM
