last time guys im almost done wit my setup b20/vtec in dc
Old Jun 14, 2005 | 12:05 AM
allmotorek8's Avatar
Default last time guys im almost done wit my setup b20/vtec in dc
ok guys what do i need to have a nice running b20/vtec in a dc ? also want to get some decent numbers anywhere between low 12's to mid 14's ? just give me a good setup with everything cuz i got some parts but i just need to know what im missing this is my quick list ? tell me what im missing? every little bit helps?
so far got
-b20z wit str block gaurd (block is bare)
-MSD 6AL ignition w/ 2 step rev limitor, SS Blaster coil and new GSR MSD Dizzy cap
-eagle rods
-aebs head studs
-crower cams 63402 ( are these any good got them in a good package deal)
-STR 68mm Throttle body
-aem fuel rail, fuel pressure regualtor, and guage
-310cc injectors
-rlz valve springs and retainers
-str cam seal
-rci cam gears
-aem pulleys
p.s. no bashing just info please thanx
Old Jun 14, 2005 | 12:38 AM
GradyDC5's Avatar
You will def need those injectors.
Old Jun 14, 2005 | 05:17 AM
Phatch99's Avatar
Default Re: (ReallySlowEg)
water pump and oil pump. b20/gsr
Old Jun 14, 2005 | 01:48 PM
Default Re: (Phatch99)
ight i know bout that stuff im talkin like what else performace stuff will i need?
Old Jun 14, 2005 | 08:00 PM
HBK GABE's Avatar
Default Re: (allmotorek8)
m22 or skunk2 pro1 cams, and hondata or something to tune on a dyno.
Old Jun 20, 2005 | 05:00 PM
SuperImport's Avatar
Default Re: (626CivicSi)
depends what you want.. im runnin endyn rw 13.1 CR with toda spec c's.. minor stuff i got a victor x IM with hondata.. get that hondata and a p28 or p30.. youre not gonna wanna start your car without it.. be careful with what you rev until.. balance and knife edge crank to around 9,500 and youll be good
Old Jun 21, 2005 | 04:00 PM
Default Re: (SuperImport)
ight thanx im just tryin to get around 240 from a b20/vtec? il keep u guys posted
bump
joshmsartin
Mar 28, 2010 07:09 PM
z06eateR
Jan 3, 2010 06:15 AM
JDMs1eeper
64
Feb 22, 2004 02:10 PM
SpeedMonkeyRacing
Nov 26, 2001 04:15 PM
