Thinking of swaping a B16 in my DA...questions??
I want to retain power steering and A/C
for the power steering do I use the 1st gen GS-R or can i use my stock one.
as for the A/C im assuming i can use the stock since its a Bseries block anyway.
can someone point me in the right direction please. thanks
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEF-9 »</TD></TR><TR><TD CLASS="quote">I want to retain power steering and A/C
can someone point me in the right direction please. thanks</TD></TR></TABLE>
I don't think you'll have a problem with any of that. I did.
If its the first gen B16 from japan, the power steering pump mount bracket which mounts on the head is different than the stock b18a PS bracket. So make sure you get the B16 bracket, hopefully the pump would be the same but I'm not sure.
I had a 1st gen b16 head on a b18a block and I just removed the PS cause the head didn't come with the bracket.
jdmmugeneg6
Jul 11, 2004 10:30 AM
