Suspension & Brakes Theory, alignment, spring rates....
X Bar
Old Jun 13, 2005 | 11:09 PM
eboixing's Avatar
Default X Bar
Anybody know the specs for this? I really want to do the X Bars to my integra.
Any kinda of info would help. Thanks
Old Jun 14, 2005 | 06:31 AM
GSpeedR's Avatar
Default Re: X Bar (xxazn2nrxx)
You will no longer have a usable rear seat. Actual chassis stiffening will probably not be that noticable.
With that said, this particular design is shitty. Every single mount is in bending due to the offsets of the crossbeam beams, and the load paths are random.
Old Jun 14, 2005 | 07:14 AM
be.twenty's Avatar
So a better design would be if it was all one piece.. the X's I mean.. basically welded together?
Old Jun 14, 2005 | 07:17 AM
00R101's Avatar
I do not think an X Bar is worth the weight. There are lots of cheaper things you can do for your suspension that will make a bigger improvement. If you really have your heart set on chassis stiffening then go with a roll bar or cage and get some real stiffness and safety!
Old Jun 14, 2005 | 08:54 AM
bad-monkey's Avatar
the m0r3 barZ the Be77@r!
it's a waste of space, money, time, metal.
Del_Sol_s
Jul 3, 2005 11:24 PM
130R
Jun 8, 2004 05:34 PM
seannabend
49
Nov 13, 2003 11:45 AM
TypeSH
Apr 2, 2002 10:01 AM
DSC
15
Mar 27, 2002 09:50 PM
