done ajusting my valves and
Old Feb 10, 2002 | 10:04 PM
balistic CRX's Avatar
Default done ajusting my valves and
done fixing my valves and seems to me that it ran alot better. just like i gained more torque or something. And it got alot quieter.
have anyone experince this after fixing ther valves?
Old Feb 10, 2002 | 10:49 PM
FitCRX's Avatar
Default Re: done ajusting my valves and (balistic CRX)
How long did it take to adjust?
Old Feb 11, 2002 | 05:05 AM
keithv's Avatar
Default Re: done ajusting my valves and (FitCRX)
it takes about an hour on a dohc...
...and you get this great back ache.
Old Feb 11, 2002 | 05:20 AM
brusk's Avatar
I adjusted mine on my ZC and it's alot quieter seems to do better in the midrange but now isn't as good in the high end of things. I stopped ragging on my car for awhile so maybe the airfilter is just really dirty or something, I havn't cleaned the K&N for about a year now (25K miles)
Old Feb 11, 2002 | 05:27 AM
TypeR0207's Avatar
Default Re: done ajusting my valves and (brusk)
Did you buy the special tool from Honda for adjusting it? Or did you use regular wrenches?
Old Feb 11, 2002 | 06:00 AM
keithv's Avatar
Default Re: done ajusting my valves and (TypeR0207)
i know the special tool from honda is better used on a car with vtec since the oil rail is in the way. on my ls teg and zc civic, a 12mm box wrench and flathead screw driver were all that was needed since the tops of the valves point outward.
Old Feb 11, 2002 | 06:11 AM
TypeR0207's Avatar
Default Re: done ajusting my valves and (breaka_1_9)
Since I'll be sporting a B16, guess I got to spring for the tool .... damn I'm a cheap bastard!
Old Feb 11, 2002 | 06:27 AM
keithv's Avatar
after doing one valve adjustment yourself, the tool has paid for itself 2 times over.
Old Feb 11, 2002 | 07:26 AM
Stinkalope's Avatar
New User
I agree get the tool, I have done my twice, its worth it..
Old Feb 11, 2002 | 07:58 AM
CRX7's Avatar
Default Re: done ajusting my valves and (Stinkalope)
where can you get the tool from?
honda dealer only?
Old Feb 11, 2002 | 08:17 AM
Default Re: done ajusting my valves and (CRX7)
hahahahahaha...... you really do get a damn back when doing your valves. all you need for the tools to fix your valves is 12mm open had wrench, flat head screwdiver, and a filler gauge (located at your everyday auto parts store). get the right one. do not get the one for the spark plug. it has like alot of flat peice of metal and it has numbers on it.
Old Feb 11, 2002 | 09:01 AM
keithv's Avatar
honda dealer only?
snap-on has the tool that you can buy.
the vtec valves have a 10mm locking nut whereas the non-vtec have a 12mm.
...somebody correct me if i am wrong.
Old Feb 19, 2002 | 09:24 AM
Fooser's Avatar
All I did was purchased a 10mm box wrench with the 10mm on one side and the 11mm on the other. I heated it up and bent it. Looks like this. From personal experience I would say this is the way to go, and for only $7 its a great deal compared to $40.
Oh ya heres some helpful instruction on how to do the Valve adjustment as well.
http://www.c-speedracing.com/howto/v...lveadjust.html
The only problem I had was finding the right size filler guages. What is the difference between the spark plug guages and the filler guages? I couldnt find filler guages small engough so I had to buy regular guages. Can someone update me on the difference?
[Modified by Fooser, 6:33 PM 2/19/2002]
Old Feb 19, 2002 | 11:42 AM
vsual's Avatar
Default Re: done ajusting my valves and (Fooser)
from what i think...there is no difference..i guess just the numberings on them that people are familar with.
Old Feb 19, 2002 | 11:48 AM
Fooser's Avatar
Default Re: done ajusting my valves and (vsual)
ya thats what I thought cause I have the feeler guages but they do not go small enough. So I bought standard guages, which looked exactly the same and had the mm readings. I just bent the right one to match the angle of the feeler guages. So I'm assuming its correct.
DarkSol97
Jul 31, 2006 12:17 PM
CWBETB
Nov 27, 2005 06:12 AM
hondaless
17
Jul 4, 2003 03:07 PM
earl
Mar 10, 2003 01:21 PM
hornetd23
Nov 12, 2002 08:27 PM
