Valves for the ZC head...Source?
Old Mar 4, 2003 | 10:28 PM
earl's Avatar
Default Valves for the ZC head...Source?
I can't seem to find a good source to find valves for the ZC head. They have a smaller stem diameter than the normal 5.5mm honda valve. Does anyone have a source for these valves? Can't find them at Manley or Ferra
Old Mar 4, 2003 | 10:37 PM
Sonny's Avatar
25 Year Member
Default Re: Valves for the ZC head...Source? (earl)
Are you looking for some high performance replacements or just some new ones? The 88-89 Integra valves are the same. I've heard that people have put LS valves in the ZC head, but I don't know if that's possible.
Sonny
Old Mar 4, 2003 | 10:50 PM
boosted_zc's Avatar
Default Re: Valves for the ZC head...Source? (Sonny)
I'm with ya earl, i actually talked to you a few weeks ago about this. I've searched high and low for valves for my ZC head, and springs for that matter. I've even set my valves out to get measured and compared to other valves. According to the shop i dealt with (Race Engineering) they are in a league of there own. he told me not one other Honda valve, stock or aftermarket, measured the same as the ZC ones. There either just a little too short, slightly larger diameter, and so on.... I think we're s.o.l. earl.
Old Mar 5, 2003 | 04:12 AM
CRVRX's Avatar
Default Re: Valves for the ZC head...Source? (boosted_zc)
Try calling HKS , I think they make cams and a spring set, They might have valves too.
If not ferrea , you might have to buy 2 set or so , but they cam custom make them.
Old Mar 5, 2003 | 04:55 AM
BROOD's Avatar
Default Re: Valves for the ZC head...Source? (CRVRX)
I ran into the same problems with my ZC build awhile back. I looked high and low with not much luck. The only option I could fins were custom valves built to ZC spec. At that time I did not have the funds for custom jobs...I used 89 Teg valves.
Good luck on the search, I hope you turn something up
Old Mar 5, 2003 | 06:18 AM
earl's Avatar
Default Re: Valves for the ZC head...Source? (SLPR)
Thanks for the help, everyone. If I find a source or any info, I will post it for all.
Old Mar 5, 2003 | 06:29 AM
NorCalHB's Avatar
hey earl try this web site. it is all about ZC's. http://www.thezcresource.com u may be able to find out the ? ur lookin for here. they seem to know what the hell they r talkin about when it comes to ZC's.
matt
Old Mar 5, 2003 | 08:13 AM
EFIGUY's Avatar
Default Re: Valves for the ZC head...Source? (NorCalHB)
What engine does the 88-89 integra have? If those valves will work, I'll get them..........at this point I've been working and waiting too long for aftermarket ones.
Old Mar 5, 2003 | 08:25 AM
Sonny's Avatar
25 Year Member
Default Re: Valves for the ZC head...Source? (EFIGUY)
The 86-89 Integra has the D16A1. It's a DOHC D series engine that is in many ways identical to the ZC.
Sonny
Old Mar 5, 2003 | 09:15 AM
*Boostwerks*'s Avatar
I have talked to Larry at Endyn, and he will custom machine some LS valves for the ZC which are black nitride coated.
He wanted around 200 something.
Other than that, it's pretty much the Acura dealer....
Old Mar 10, 2003 | 12:59 PM
azulito's Avatar
Default Re: Valves for the ZC head...Source? (Bryson)
I think the best and most cost effective source will be OEM D16A1 valves which are about $8-9 each from an Acura dealer. Of course custom valves can be made and some places I have found offer that service, like Web Camshafts, and Race Engineering, but the price makes it hard to justify for most apps.
I am still wondering if D16A1 valves are EXACTLY the same dimensions as the ZC. Gonna have to check on that...
Old Mar 10, 2003 | 01:21 PM
Joseph Davis's Avatar
Default Re: Valves for the ZC head...Source? (azulito)
I've heard of running LS valves in the ZC before, too. If the stem diameter is off, can you swap out the whole guide?
DarkSol97
Jul 31, 2006 12:17 PM
JDM90lsvtec
Nov 18, 2002 04:41 AM
hornetd23
Nov 12, 2002 08:27 PM
cr-x si
Sep 6, 2002 09:26 PM
