Need help getting crank pulley bolt off....
use a screw driver and lock the flywheel through the starter area. that should keep the crank from spinning. then just use your brute force to get the bolt off.
**shouldn't take that much effort.**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">use a screw driver and lock the flywheel through the starter area. that should keep the crank from spinning. then just use your brute force to get the bolt off.
**shouldn't take that much effort.**</TD></TR></TABLE>
flywheel isn't on
flywheel isn't on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrvx »</TD></TR><TR><TD CLASS="quote">
flywheel isn't on
get a flywheel and bolt it up with at least 2 bolts. then hold a screwdriver to the teeth of the flywheel and the webing of the bolck. have a friend take out the bolt.
flywheel isn't on
</TD></TR></TABLE>get a flywheel and bolt it up with at least 2 bolts. then hold a screwdriver to the teeth of the flywheel and the webing of the bolck. have a friend take out the bolt.
sayanything
Sep 22, 2010 04:47 PM
