WHAT ARE THE VALVE ADJUSTMENTS ON A GSR HEAD WITH CTR CAMS IS THERE ANY MODIFICATION?
Old Jun 13, 2005 | 08:08 PM
TOP*SECRET's Avatar
Modified by JDMDC2909 at 9:53 PM 6/19/2005
Old Jun 13, 2005 | 08:10 PM
Kendall's Avatar
Look up the valve adjustment specs for a 00-01 Integra Type R.
Old Jun 13, 2005 | 08:54 PM
TOP*SECRET's Avatar
Default Re: (Kendall)
cant find jack **** up in here!!
Old Jun 13, 2005 | 09:03 PM
Kendall's Avatar
Searching the Archives in the ITR forum for "valve adjustment" found 94 results.
https://honda-tech.com/zerothread?id=550113
Look harder next time.
Old Jun 14, 2005 | 06:22 PM
TrackSpeedRacing's Avatar
Default Re: WHAT ARE THE VALVE ADJUSTMENTS ON A GSR HEAD WITH CTR CAMS IS THERE ANY MODIFICATION? (JDMDC2909
.007 on the intake side
.009 on the exhaust side
Old Jun 14, 2005 | 06:55 PM
TOP*SECRET's Avatar
THNX..Well im gong b20vtec so do I need to notch the pistons if I put the ctr cams in...?
Old Jun 14, 2005 | 07:05 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2909 &raquo;</TD></TR><TR><TD CLASS="quote">THNX..Well im gong b20vtec so do I need to notch the pistons if I put the ctr cams in...?</TD></TR></TABLE>
No, you need to replace the pistons with appropriate ones. Notching makes an unbalanced motor even more unbalanced, not to mention it lowers the already low compression. But if you use CTR cams in a CRVTEC, then yes you will have valve clearance issues.
VTIargentina
Nov 17, 2009 01:18 PM
94IntegraLs04
May 10, 2006 08:38 PM
crazyc@SRTmotorsports
Apr 20, 2006 01:04 PM
SPOON_FED_DC_2
Apr 4, 2005 09:33 PM
InfamousRS
Apr 20, 2002 05:09 PM
