ECU Question
Old Jun 13, 2005 | 04:38 PM
Guru Designs's Avatar
* B A N N E D *
Default ECU Question
I just put my integra back together after a long winter of sitting down. i replaced the knock sensor and a few misc heater hoses. now i turn on the car and it will start but the check engine light turns on and i hear a loud relay clicking the same time the check engine light flickers. i try to connect my snap-on diagnostic machine and it goes crazy. Can this be a bad ecu? anything else that might cause this. thanks.
Old Jun 13, 2005 | 04:45 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ECU Question (tobe2be)
ODBII will sometimes store a CEL for an ECU problem.
* B A N N E D *
94 gsr with a type r head. obd1
Old Jun 13, 2005 | 05:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (tobe2be)
My Haynes manual says code 0 (CEL) for a faulty ECU (OBDI). I'm not sure how code 0 would display. Perhaps the ECU won't show any CELs.
Can you scanner communicate with the ECU without the car running?
Old Jun 13, 2005 | 05:06 PM
slomofo's Avatar
GDD Member
Your scanner's probably a piece of ****. I have the Snap-On MT2500 and I've replaced it four times in five years. Try manually gathering the codes by jumping the 2 pin connector and counting the flashes, then remove HON-1 from your data link connector and use MULTI-1 to pull up codes list.
da9blk1
Jul 19, 2010 08:04 PM
phiberoptik
Dec 6, 2003 05:06 PM
kim_2_da_chee
May 30, 2003 06:18 PM
EF_LSVtec
Oct 31, 2002 07:38 AM
RedRacerCivic
Dec 6, 2001 11:45 AM
