Weird Cold Idle*SEARCHED
Old Jun 13, 2005 | 01:36 PM
d16efsedan's Avatar
Default Weird Cold Idle*SEARCHED
ok when i go to start my car up it idles really funny it jumped from 500 to 1000 rpm's back and forth until its warmed up?just wondering if anyone knew where to start?TIA...
Old Jun 13, 2005 | 01:38 PM
tallguy's Avatar
Default Re: Weird Cold Idle*SEARCHED (d16efhatch)
vacuum
Old Jun 13, 2005 | 01:45 PM
d16efsedan's Avatar
Default Re: Weird Cold Idle*SEARCHED (tallguy)
thanks man.but wouldnt a vacuum leake do it all the time?it only does it when the car is cold...
Old Jun 13, 2005 | 01:48 PM
aeonsi's Avatar
test the EVAC(I think?) its the cylinder shaped thingy on the rear of the intake manifold. had the same problem on my old 89si, though it did it all the time. its has alot to do with idling.
Old Jun 14, 2005 | 10:58 AM
716pro's Avatar
Default Re: Weird Cold Idle*SEARCHED (aeonsi)
you didnt search because if you did you would of got a million topics. Try searching again and use the keywords Idle Air control or IAC, or just idle. Its most likely your IAC or you FITV.
Ericjergs
Nov 16, 2018 07:06 AM
Apple395
Aug 16, 2013 10:13 PM
leonard1818
Nov 23, 2005 12:12 PM
DIYMIKE
Nov 14, 2004 06:03 PM
See Are X
Mar 24, 2004 06:09 PM
