zc vtec exactly the same as z6?
I went to a local engine importer, he didn't have z6's put he kept pushing me the zc vtec. I just want to know if there are any differences between the two. Do I have to worry about obd0 or 1 or 2. How about timing belt, during a search some dude put up that it needs a VX t-belt. Also, things like pistons(for when I go to build it), sensors, vtec **** etc.
o2 sensor 1 wire or 4wire, can I run a p28 like I would w/ a z6?
Thanks guys.
Thanks guys.
The only difference I know of is the Z6 is 1.6L and the VTEC SOHC ZC is 1.5L, don't know if all Z6 parts would work for it but I would venture to say no.
i had one of these motors, they are impossible to find info on lol, but i have been told that they are pretty much the exact same as the d16z6
too damned many versions of the ZC
ZC Honda CRX (JDM) 1990-1993
ZC Honda CRX Si16/1.6i (JDM) 1989-1992
ZC Honda CRX Si (JDM) 1985-1987
ZC Acura Integra (JDM) 1990-1993
ZC Acura Integra (JDM) 1986-1989
ZC Honda Civic Si (JDM) 1986-1987
ZC Honda Civic Si (JDM) 1988-1991
Not to jack your thread but I got a JDM 1.6 vtec stamped D16A(no number after A). Was told it is the same as ZC, which is the same as the D16Z6. Anyone know if there is a difference between the three?
I've got a JDM SOHC ZC VTEC motor, fully rebuilt with z6 parts
only thing I've found different was the cam
I've got like 2 threads on this....who didn't use thier search button?
If they were the same, they would both be D16Z6. haha If you have OBD1, of course it would be better to get OBD1, or else you would have to make other minor modifications. Yes, you can run the P28 with the ZC. The ZC is a decent motor, note that there was SOHC VTEC and non-VTEC, then DOHC non-VTEC, all ZC motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pioneer162 »</TD></TR><TR><TD CLASS="quote">I've got a JDM SOHC ZC VTEC motor, fully rebuilt with z6 parts
lol, I did search. Hence, the part about the VX timing belt. But yeah, it's hard finding info, and searching. Can't search for ZC, so I tried d16zc. That was decent. Hey hook me up w/ ur threads.
EDIT I went through your threads. Did you use the p28? How does it run?
Modified by integraXTC at 11:07 PM 6/13/2005
</TD></TR></TABLE>lol, I did search. Hence, the part about the VX timing belt. But yeah, it's hard finding info, and searching. Can't search for ZC, so I tried d16zc. That was decent. Hey hook me up w/ ur threads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCart »</TD></TR><TR><TD CLASS="quote">Not to jack your thread but I got a JDM 1.6 vtec stamped D16A(no number after A). Was told it is the same as ZC, which is the same as the D16Z6. Anyone know if there is a difference between the three? </TD></TR></TABLE>
I don't know man. I was gonna say it's off the 1g Teg. But you say it has vtec, so that means it's sohc. I don't know what's wrong w/ that bitch. Maybe it's a mini-me.
Not a mini-me. Has anyone actually seen a block with only a D16A stamp. If have read posts one the subject of the mysterious ZC and the consensus seems to say that the sohc version is same as z6 accept for a cam difference. Pioneer, what was the cam difference.
MidwestSi
Sep 8, 2004 01:59 PM
