for all u who have done 5th gen HID's and projector retrofits...
ok, i just got a set of BMW E46 headlights with HID's and Projectors, and since there is no diagram, i get the idea on how to put in the projectors, but on the HID's there are 3 wires, red, green and black. i am assuming that the red is positive and black is negative, but what is the green? and how did you connect the stock red and black headlight wires, with the HID ones? did u just splice them together? all input is greatly appreciated. thanks
ive searched and found nuthin...
the red, black, and green wires are the wires for your high beam motor, you will need a relay for that, theres a write up for that on HIDplanet.com
As for the regular low beams, you just need to cut the Honda connectors off your car, and connect the honda red and black wires to the two-prong harness on the ballast.
PM me if you need more details
here is what i bought. http://cgi.ebay.com/ebaymotors...&rd=1 there a total of 6 wires ( two sets of red green and black) coming from the ballast. one set goes to a lil black box u can see in the pic. and from that box, it goes to the bulb. but the other set of the three wires, is there, to connect to the car. from what i can see, there is no two prong harness on the ballast
do u have a link to this write up??
Modified by AEMPrelude916 at 2:46 PM 6/13/2005
ok, i just went out and bought all the stuff for the relay, so i get that part. and my dumb *** just found the spot on the ballast where the low beam plugs go into. here's the link on the relay, does this look like what u did? with the same parts and all that?? just to make sure. thanks
http://www.hidplanet.com/forum...t=138
When I hooked up my ballast, I just spliced into my OEM harness...I've had mine hooked up for about 8 months now with no problems at all...Good luck with your retrofit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">When I hooked up my ballast, I just spliced into my OEM harness...I've had mine hooked up for about 8 months now with no problems at all...Good luck with your retrofit
did u have a bi xenon kit? cuz ive heard if u try to run the bi xenon kit on 2 of the 3 wires, it will blow ur solenoid. i was hoping i cud just splice into my oem harness, but i want the hi and lo beam use. cuz i currently dont have hi beams, and it sux out in the country. thanks tho. imma need all the luck i can get
</TD></TR></TABLE>did u have a bi xenon kit? cuz ive heard if u try to run the bi xenon kit on 2 of the 3 wires, it will blow ur solenoid. i was hoping i cud just splice into my oem harness, but i want the hi and lo beam use. cuz i currently dont have hi beams, and it sux out in the country. thanks tho. imma need all the luck i can get
ok, i just made the relay switch, but now, i still have a problem. the small plug coming out of the ballast goes to the high beam solenoid. i kno. it just plugs rite in. so did i:
1) even need to make a relay??
2) also, where the hell do the OEM high beam wires plug in to? i kno where the low beams go, into the plug with two prongs, but the other has 3 prongs, and i dunno what that is ther for. so to me, it doesnt even look like i had to make a relay.. im so confused...
so will it work, if i just plug in my low beams?? - meaning the low beams will work, but the high beams wont??
WTF?
WTF?
ok, then how?? the only free plugs i have are one that has two prongs in it, which is for the low beams, and the other has three really skinny prongs in it. what OEM wires go to each? just to be sure
doubleoazn03
Jan 6, 2012 03:54 PM
phatrick2332
Jul 13, 2004 01:22 PM
