Finished b18 swap Idle/bogging problems?
Old Jun 13, 2005 | 12:07 PM
Stoich's Avatar
Default Finished b18 swap Idle/bogging problems? PICS
First the setup
Jdm B18 Converted to OBD1 running a P28
I just turned it over for the first time and it idles like **** and when you try and give it gas it sputters and bogs i gotta pump the gas to get the revs up and when it drops to idle is stalls out.
Thanks for any help
Modified by Stoich at 10:10 PM 6/13/2005
Old Jun 13, 2005 | 12:42 PM
Stoich's Avatar
Default Re: Finished b18 swap Idle/bogging problems? (Stoich)
I have not driven her in like 3 weeks im dying here
HELP MEH
Old Jun 13, 2005 | 12:45 PM
MONSTERZC's Avatar
it sounds like the timing may be off or the spark plugs wires are in the wrong order
and double check to make sure you have the map sensor pluged up
Modified by MONSTERZC at 10:04 PM 6/13/2005
Old Jun 13, 2005 | 12:47 PM
technine's Avatar
Check your vacuum ports and make sure that your MAP sensor is hooked up (happend to me).Check you timing, ignition timing and cam timing.
Sounds like you don't have the MAP sensor hooked up because when I didn't I had the same problem as you. Funny, I drove 3 miles to get to my house like that and barely made it, fixed the vac line and instant power.
Old Jun 13, 2005 | 01:10 PM
Stoich's Avatar
Default Re: Finished b18 swap Idle/bogging problems? (technine)
all the vacuum ports seem to be good and the motor was running in another EF and ran fine however that one was running obd0 and i converted to obd1 and swaped the dizzy
could that be it?
Modified by Stoich at 9:13 PM 7/4/2005
Old Jun 13, 2005 | 01:11 PM
Stoich's Avatar
I had been under the hott sun all day so maybe im missing something obvious
Old Jun 13, 2005 | 01:18 PM
MONSTERZC's Avatar
double check your wiring and make sure you have all the grounds hooked up i see the one that from the motor to above the left headlight is not hooked up also is the ground from the body to the tranny hooked up you could try to convert it back to obo and see how it runs if you can
Old Jun 13, 2005 | 01:23 PM
phatstyles's Avatar
Default Re: Finished b18 swap Idle/bogging problems? (MONSTERZC)
check your timing looks like your dizzy is a little off
Old Jun 13, 2005 | 01:29 PM
MONSTERZC's Avatar
Default Re: Finished b18 swap Idle/bogging problems? (prodigyproject)
that was my first guess before he even posted the pics
Old Jun 13, 2005 | 01:56 PM
Stoich's Avatar
Well im getting a single long flash from the CE light which is O2 sensor
But would that cause this problem?
Old Jun 13, 2005 | 02:06 PM
Stoich's Avatar
IAT is fine, CEL when pulling codes gives nothing but a constant light. cel lights when the car is running and stumblingh
ARGH !!!!!
Modified by Stoich at 11:50 PM 6/13/2005
Old Jun 13, 2005 | 08:05 PM
Stoich's Avatar
bump
Old Jun 13, 2005 | 08:29 PM
Thrillhouse's Avatar
make sure the MAP and TPS plugs arent swapped. This COULD throw an O2 code because if the map sensor or TPS go shitty then the ecu will go full rich to protect the motor. Try that. Also check to make sure your TPS is set to .49 volts at idle. If its stalling out at idle most likely its not getting enough gas, OR its getting way too much gas at idle. A good way to check this is pull the plugs to see if they are fouled. Also like the other guys said check your wiring. Hope it helps a lil
Old Jun 14, 2005 | 07:32 AM
MONSTERZC's Avatar
do you have another ecu lying around or can you borrow one from a friend. i think your ecu may be cooked.
Old Jul 3, 2005 | 06:27 AM
Stoich's Avatar
Well the new chipped ecu is in and the car still runs like ***
I got a timing light on there and no matter what direction i move the dizzy the timing wont come in to where is supposed to be.
Suggestions?
ARGH
Old Jul 3, 2005 | 11:02 AM
Stoich's Avatar
BUmp jedi scum
Old Jul 3, 2005 | 04:30 PM
Stoich's Avatar
Old Jul 3, 2005 | 05:51 PM
CRseXy's Avatar
to adjust timming, you gotta jump 2 wires, theres a little white plug all the way to the right. like right across from the timming belt cover. on inside of the driver side fender, under the hood.
When you try to adjust the timming, the computer adjustest its self, that jumper keeps the computer from changing. Jump it using a paperclip.
Old Jul 4, 2005 | 04:16 AM
Stoich's Avatar
Default Re: Finished b18 swap Idle/bogging problems? (CRseXy)
ic is it the diagnostic jumper ?
Since i converted to obd1 the new harness came with the two wires you cross to get the codes off the ecu are these the ones you mean ?
If so i may i have found why i could not set the timing lol
Old Jul 4, 2005 | 10:32 AM
Stoich's Avatar
Bump dump
Teach me !!
Old Jul 4, 2005 | 12:11 PM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">ic is it the diagnostic jumper ?
If so i may i have found why i could not set the timing lol </TD></TR></TABLE>
No, Check your Helms Manual.
Old Jul 4, 2005 | 12:13 PM
Stoich's Avatar
Well the car still has a **** idle and wont rev
Cam timing is dead on
Ignition timing is dead on
Ideas?
Old Jul 4, 2005 | 12:21 PM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">Well the car still has a **** idle and wont rev
Ideas?</TD></TR></TABLE>
make sure there are no bubbles in your Coolent, sometimes the bubbles will hang on to your IAC valve and **** it up, burp your rad, and try agian.
Old Jul 5, 2005 | 03:15 AM
Stoich's Avatar
The dizzy i got here in the Fs section has TD81 stamped on it
How do i tell if its OBD1 or obd2?
Old Jul 5, 2005 | 03:23 AM
Stoich's Avatar
distributor king shows this as a obd2 dizzy
When i got it on HT that **** told me it was a obd 1
this could explain my problem !
http://www.distributorking.com...D44&0
