another axles question... tired of getting conflicting info
Old Jun 13, 2005 | 11:14 AM
steronz's Avatar
Default another axles question... tired of getting conflicting info
Ok, my car has eaten its axles after about 5000 miles. JDM b16 swap into a crx, hasport mounts, J1 transmission, 91 integra intermediate shaft, and hasport EFBAXCMP axles. i didn't have to remove any dust shields, and everything seemed like it bolted up just fine. the car is lowered about 3/4" with a camber kit, camber is set to 0 degrees. did i get the right axles? why are they popping so much already? i want to take this up with hasport, but i want to make sure i didn't screw anything up first.
Old Jun 13, 2005 | 11:23 AM
EP3_05's Avatar
Default Re: another axles question... tired of getting conflicting info (steronz)
Do you get alot of wheel hop? Wheel hop will break axles pretty easily. Call Hasport and discuss it with them.
Old Jun 13, 2005 | 11:58 AM
steronz's Avatar
i've been running a jimfab crossmember since i did the swap, so no wheel hop.
Old Jun 13, 2005 | 12:23 PM
MONSTERZC's Avatar
Default Re: (steronz)
what kinda of pooping sound is it only when you turn
Old Jun 13, 2005 | 12:24 PM
MONSTERZC's Avatar
Default Re: (MONSTERZC)
maybe your motor mounts are loose have you doubled check to see if the are tight
did you install them right make sure everything was nice in tight maybe hasport sent you the wrong axles the best way to find out is just to give them a call and discuss this with them
Old Jun 13, 2005 | 02:20 PM
steronz's Avatar
yeah, everything's still tight and the way it should be. i'll call hasport tomorrow, i just want to make sure i ordered the right axles to work with this setup so i don't sound like an idiot when i talk to them.
civic-r11
Apr 17, 2017 05:07 AM
wannaBjdmca6
Suspension & Brakes
Oct 16, 2010 05:25 PM
Lambo123
K Series
13
Oct 1, 2009 11:59 AM
SimplyTron
Oct 2, 2006 08:50 PM
rioninja
Apr 18, 2001 03:14 PM
