1996 Hatchback / 2000 Front End Conversion - Parts List!? (Searched)
Old Jun 13, 2005 | 09:53 AM
GReddyTurboCoupe's Avatar
Default 1996 Hatchback / 2000 Front End Conversion - Parts List!? (Searched)
I've Searched And Searched, and haven't come up with DEFINITE Answer.
I''m looking for a parts list.
99-00' Civic Headlights
99-00' Civic Front Bumper
99-00' Civic Grill (Getting Type-R / Mugen)
99-00' Civic Hood (VIS / Fiber Images/ Or Other Recommend OEM Styles)
Now The Main Question is Here, do i need:
99-00' Civic Rad Support ?!?!?
And IThink if i do need that, then that completes the process, front what i understand, can anyone let me know if there is any wirirng or any other things that need attention that i am over looking? i'm pretty sure with all these parts its a bolt on process, correct? Okay, thanks guys.
Old Jun 13, 2005 | 10:08 AM
GoldBadge's Avatar
Fenders, too. Don't know about the rad support, though.
Old Jun 13, 2005 | 10:13 AM
nightshocker's Avatar
Default Re: 1996 Hatchback / 2000 Front End Conversion - Parts List!? (brianmgroverpeterson)
you wont need the rad support and everything is plug and play no extra wiring. unless you get 99-00 fogs.
Old Jun 13, 2005 | 10:44 AM
ecahatch's Avatar
Senor Miembro
if u dont get the 99-00 rad support, you need to trim the inside part of the bumper by the grill...
youll see what im talking about when u try to put em in....
Old Jun 13, 2005 | 02:09 PM
JDMSiGuy17's Avatar
Default Re: (ECAhatch)
lots of people have done it so if you start doing it and run into a problem you can just ask around for some hlp. but your gonna need 99-00 hood, headlights, fenders, front bumper and grill thats it. good luck and post some pics when you get done!
Old Jun 13, 2005 | 03:06 PM
Brian Hinson's Avatar
Ive put the 99-00 front end on my 97 Hatch. You need fenders, hood, headlights, grill, and bumper. Its all plug and play. I didnt use the 99-00 Rad support and it works fine, but I can see why you would want to.
Old Jun 13, 2005 | 03:10 PM
huntarrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">if u dont get the 99-00 rad support, you need to trim the inside part of the bumper by the grill...
youll see what im talking about when u try to put em in....</TD></TR></TABLE>
exactly.
Old Jun 13, 2005 | 06:59 PM
distortedfuture's Avatar
Default Re: 1996 Hatchback / 2000 Front End Conversion - Parts List!? (Brian Hinson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian Hinson &raquo;</TD></TR><TR><TD CLASS="quote">Ive put the 99-00 front end on my 97 Hatch. You need fenders, hood, headlights, grill, and bumper. Its all plug and play. I didnt use the 99-00 Rad support and it works fine, but I can see why you would want to.</TD></TR></TABLE>
Old Jun 13, 2005 | 07:15 PM
charmersfh's Avatar
another Amen to that...
Old Jun 13, 2005 | 07:19 PM
b18blackek's Avatar
no need for rad support jus and some fenders and u str8
Old Jun 13, 2005 | 07:20 PM
b18blackek's Avatar
go to passwordjdm.com they sell the whole JDM 99 civic conversion wit mad options.
Old Jun 13, 2005 | 07:21 PM
b18blackek's Avatar
here u go i made it easy for u
http://passwordjdm.com/product.asp?P_ID=1283
Old Jun 13, 2005 | 07:44 PM
ninjaEF's Avatar
Default Re: 1996 Hatchback / 2000 Front End Conversion - Parts List!? (B18BlackEK)
you don't need to change the rad support!
Old Jun 13, 2005 | 07:49 PM
TheNasty0ne's Avatar
Default Re: 1996 Hatchback / 2000 Front End Conversion - Parts List!? (ninjaek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaek4 &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to change the rad support! </TD></TR></TABLE>
You shoulda searched I know theres a bunch of stuff on here...... conversion is easy...plug and play like everyone else is saying....
Take the time to line up your body lines....make it look clean and your all set
Old Jun 13, 2005 | 07:57 PM
ninjaEF's Avatar
btw my car is a 98 converted to 99 front
&lt;----------------see the atvatar
parts list:
2 99-00 civic fenders
2 99-00 civic headlights
1 99-00 civic front bumper
1 99-00 civic hood
1 99-00 civic grille assy
Old Jun 13, 2005 | 08:08 PM
Top-Fuel's Avatar
I've done the research on the front 99-00 conversion as well a while ago, because I have a 97 hatch and you dont' need to change to 99-00 rad support or remove anything at all. IT SHOULD BE PLUG AND PLAY .....there are few examples with pictures on the FAQ if i remember correctly and some guys DID replace their rad support and still worked fine.
But basically you dont' need to worry about your rad at all, just replace:
fender,hood,grill,bumper,headlights...good luck!
Old Jun 13, 2005 | 10:09 PM
itr-00-436's Avatar
those prices is through the roof,dam
Old Jun 13, 2005 | 10:12 PM
ninjaEF's Avatar
Default Re: (itr-00-436)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr-00-436 &raquo;</TD></TR><TR><TD CLASS="quote">those prices is through the roof,dam</TD></TR></TABLE>
are you ok?
Old Jun 18, 2005 | 09:31 PM
charmersfh's Avatar
I find it easier to use the REAL OEM Honda fenders,bumper,headlights, and hood. It'll bolt up with nicer spacing.
Old Jun 18, 2005 | 10:12 PM
PinkMaggit's Avatar
Default Re: (charmersfh)
wow $1500 for front end conversion from password
Old Jun 18, 2005 | 10:48 PM
JDMSiGuy17's Avatar
Default Re: (PinkMaggit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinkMaggit &raquo;</TD></TR><TR><TD CLASS="quote">wow $1500 for front end conversion from password</TD></TR></TABLE>
yes thats expensive but look at the stuff you get for it! lots of good but expensive stuff and they are all brand new!
Old Jun 20, 2005 | 01:48 PM
tthumma10's Avatar
Default Re: (JDMSiGuy17)
I did this conversion on my hatch. You don't need the rad support, but the holes where the bumper bolts to the rad support need to be extended.
Old Jun 20, 2005 | 06:21 PM
Forrest Gump 9's Avatar
How about foe an EG?
dudeomega2000
12
Jun 13, 2008 01:29 PM
EJK1D
Jun 13, 2008 11:01 AM
FUPAH8TR
16
Oct 8, 2006 09:36 PM
gsr336
13
Aug 16, 2006 08:06 PM
sightless
Dec 10, 2004 05:04 PM
