what is the redline and vtec activation point on a stock p28?
Old Jun 13, 2005 | 09:07 AM
northkai3's Avatar
Default what is the redline and vtec activation point on a stock p28?
Old Jun 13, 2005 | 09:09 AM
D15Bbigred's Avatar
correct if i'm wrong but i wanna say 4800...
Old Jun 13, 2005 | 09:13 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (EG1racer)
4800 vtec and 7500 fuel cut
Old Jun 13, 2005 | 09:16 AM
TheNasty0ne's Avatar
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">4800 vtec and 7500 fuel cut</TD></TR></TABLE>
Dang...didnt realize it kicked it that low
What car is a p28 from?
Old Jun 13, 2005 | 09:19 AM
northkai3's Avatar
Default Re: (OoBryan)
i have it in a d15b sohc vtec motor jspec but the vtec is not hooked up so it doesnt sound like i sound like i should take it past 6500 but im not sure what is the motor capable of handling ?
Old Jun 13, 2005 | 09:20 AM
northkai3's Avatar
Default Re: (northkai3)
im getting the vtec hooked up soon!
Old Jun 13, 2005 | 09:22 AM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoBryan &raquo;</TD></TR><TR><TD CLASS="quote">
What car is a p28 from?</TD></TR></TABLE>
92-95 EX/Si with the D16Z6.
Old Jun 13, 2005 | 09:23 AM
Morning Call's Avatar
p28s come with d16z6's i know that much
i always thought it was 5200, but i gues it makes more sense at 4800 as i seem to pickup speed there rather then 5200
redline i thought was 7200, but i dono..
Old Jun 13, 2005 | 09:25 AM
northkai3's Avatar
Default Re: (Morning Call)
anyways what can that engine handle? and i just got a new intake manifold i got a d16y8 is it hard to install any adivice or info?
Evs-One's Avatar
Solbros Owns Me
redline is 7200...fuel cut is 7500 tho
Old Jun 13, 2005 | 09:27 AM
northkai3's Avatar
but do u think a stock d15b jspec can handle 7200 rpms?
Old Jun 13, 2005 | 09:34 AM
northkai3's Avatar
Old Jun 13, 2005 | 09:40 AM
northkai3's Avatar
anyone
Old Jun 13, 2005 | 09:43 AM
Evs-One's Avatar
Solbros Owns Me
of course. It's just a de-stroked Z6....should be able to handle the revs as well as a 1.6. No need to rev that high all the time tho....and you shouldn't be bouncing off the limiter. Shift at 7200 and be coo
Old Jun 13, 2005 | 09:54 AM
D15Bbigred's Avatar
well ecu wise i belive its 4800-4900, but it depends on how yur car is running. if its cold, fat chance. but on a regular day at normal temp it should be those numbers. also with the y8 manifold, i believe it fits, search a little more, but prepare to have fun with coolant. YUCK.....
Old Jun 13, 2005 | 03:01 PM
Hurricane's Avatar
VTEC engagement specs on a typical Z6 with P28 is 4800-5200rpm according to throttle position and engine load.
Old Jun 13, 2005 | 03:09 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">of course. It's just a de-stroked Z6....should be able to handle the revs as well as a 1.6. No need to rev that high all the time tho....and you shouldn't be bouncing off the limiter. Shift at 7200 and be coo</TD></TR></TABLE>
Shifting even at redline is too high IMHO. The Z6/D15B's stop making power at about 6,800-6,900, so I hardly ever shift past 7000. I remember when I had my exospeed stage 2 cam, that sucker kept pulling all the way to 7500...but when I pulled out the cam for my turbo project I could really see how much the stock cam sucked *** in terms of upper RPM power delivery.
Old Jun 13, 2005 | 07:41 PM
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Shifting even at redline is too high IMHO. The Z6/D15B's stop making power at about 6,800-6,900, so I hardly ever shift past 7000. I remember when I had my exospeed stage 2 cam, that sucker kept pulling all the way to 7500...but when I pulled out the cam for my turbo project I could really see how much the stock cam sucked *** in terms of upper RPM power delivery.</TD></TR></TABLE>
True I use to shift at 6,500 if you look at the dyno charts for a stock single cam....and look at the curves you should shift so you stay in the power band
Old Jun 17, 2005 | 01:14 PM
Evs-One's Avatar
Solbros Owns Me
you also gotta think gearing then too. I'd rather be out of my power band in 2nd gear before shifting into 3rd, then to shift into 3rd too early and be dog slow cause now I'm below the powerband
Old Jun 17, 2005 | 04:29 PM
nota-eg's Avatar
I thought fuel cut on the P28 was in the 8500-9000 range. I remember I accidentally downshifted from 5th to 2nd (meant to hit 4th) and the car when "whaaaaaa" then went silent. Looked at the tach and it was at 8800.
Old Jul 6, 2005 | 08:03 AM
JICEK9's Avatar
Default Re: (nota-eg)
Old Jul 6, 2005 | 08:04 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">I thought fuel cut on the P28 was in the 8500-9000 range. I remember I accidentally downshifted from 5th to 2nd (meant to hit 4th) and the car when "whaaaaaa" then went silent. Looked at the tach and it was at 8800.</TD></TR></TABLE>
there is no cut off when you mis-shift. I've seen a couple s2k and lude motors pop this way.
Old Jul 6, 2005 | 08:06 AM
nota-eg's Avatar
Default Re: (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">there is no cut off when you mis-shift. I've seen a couple s2k and lude motors pop this way. </TD></TR></TABLE>
I don't know. I just remember shifting from 5th to 2nd, the car taking off like a rocket, then going completely silent.
Old Jul 6, 2005 | 09:09 AM
93CX's Avatar
I misshifted my old d16z6 WAYYYY off the tach before, nasty transmission grinds. I've misshifted my new b16 to 10k before too. Grinds 2nd, 3rd, 4th, lol.
Old Jul 6, 2005 | 09:18 AM
JDM-EJ1's Avatar
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
92-95 EX/Si with the D16Z6.</TD></TR></TABLE>
Yup!
