Error Code: 73 random misfire cylinder 3
Gotta question.....
I keep getting the same code. I changed my spark plugs and put my stock plug wires back in. Also changed my distributor Cap. Need help!!!!
Modified by rnl04 at 10:11 AM 6/13/2005
I would suggest you to also change your distributor cap/rotor just to see if it acts differently. Are your plugs gapped correctly? How old are your stock plug wires? There is a chance that those may be faulty as well.
hehehe I forgot to mention that i changed the CAP. I got NGK spark plugs from pep boys. Dont they come pre gapped already?? Maybe i should check them again.
I forgot to mention that i did changed the CAP. The wires are my stock wires that ive had since ive gottent he car. Ill try getting new plugs to see if that is the problem.
help this man out ..cause iv got random misfires too
iv replaced : entire distributor
IAC valve
spark plugs and wires
injectors
fuel filter
compression test turned out good all across the board
this is getting to me hah ...cant figure out what it is
possibly FPR ? replaced injectors .. seem to run fine
maybe i need a valve adjustment even thow the compression test is good ?
IAC valve
injectors
fuel filter
mynameizstitch
Jun 8, 2009 07:29 AM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
AGB5901
Jan 20, 2004 03:20 PM
