dont know were my oil is goin
hey guys i just put a motor in my integra and it is not holding oil, i replaced the rear main, so i dont think it is leakin there. it isnt noticable any were, were do you guys think its goin? thanks
Guest
Posts: n/a
How many miles are on it. I've noticed that after Honda engine get around 50k-60k they seem to drink alot of oil. Make sure to check it around 2000-2500 miles after an oil change, it usually needs a quart.
i filled with 4 quarts checked my dip it was perfect, ran the car then noticed quiete a bit was gone when i checked it again, drained all of the oil and did the same thing again same result i dont think it would burn that much oilthat fast, im gonna try to run it longer though
quite a bit is not the answer i was looking for. More like" I filled it up it was good, 2 weeks later i had to add XXXX to bring the level back to where is was before"
i filled it up ran it for about 5 minutes and noticed about half to a quart was gone, maybe more, were is the pcv valve located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyblack93lude »</TD></TR><TR><TD CLASS="quote">i filled it up ran it for about 5 minutes and noticed about half to a quart was gone, maybe more, were is the pcv valve located?</TD></TR></TABLE>
And there is no smoke?? no leaks??
I doubt running 5 minutes losing 1/2 quart is due to leaking from seals, they don't leak that fast, plus when you are driving the engine is in vacuum, so air should go inward instead of outward.
Either ring, oil passage (filter?), or head gasket.
Did you get more coolant than you started with? minor oil burning doesn't give noticable smoke. But 1/2 quart in 5 mins is alot.
my bad didnt get back to you sooner, but pcv valve is under the intake manifold, looks like a beige color on the gsr- wouldnt know on your model
it wasnt leaking anywhere, what happens is when the valve is not working it just lets oil through and the engine begins to burn it. the way i noticed was by checking the dipstick
