It RAINED and My car is leaking!
Old Jun 13, 2005 | 05:36 AM
Wasabithegosu's Avatar
Default It RAINED and My car is leaking!
it rained the past few days last week but i dint drive my car. when i went up to it when the rained stopped, i had puddles of water on the floor. my windows were rolled up and my sun roof was closed. what could have caused it? my step dad said it was coz of bad door sills, but im not really sure. the car is old, but so are all other crx's and i never hear any complaints of leaks. whats goin on here?
Old Jun 13, 2005 | 05:38 AM
crxnj's Avatar
Default Re: It RAINED and My car is leaking! (Wasabithegosu)
Its the windwhield..Poor water onto the windshield and watch the water leak in like crazy..It's happend on all our cars I think..There and hatch/trunk areas both eventually leak..
Old Jun 13, 2005 | 05:42 AM
ex voto's Avatar
Default Re: It RAINED and My car is leaking! (Mr.speaker)
Yep... the four doors too. Dealing with a trunk SUCKS.
Old Jun 13, 2005 | 07:10 AM
bagpipe goatee's Avatar
yeah, welcome to the club. on my hatch, the rain gutters are rusted THROUGH by the windshield underneath the rubber trim that holds water and salt in. i pulled them up and put silicone in until i can afford to pull the windshield and weld. it looks like ****, but, i guess so does the rest of my car.
Old Jun 13, 2005 | 07:17 AM
Suck my DX's Avatar
Default Re: (bagpipe goatee)
yeah all the weatherstripping on my windshield was coming off...leakin slowly butm not bad...just put some silicone under the stripping...pressed the stripping back on and held it firmly planted over night with masking tape...sealed up perfectly and ui cant even tell....with silicone its all really depends where u have to apply it...some places are discreet and some places are gonna look horrible no matter what u do...just my .02
Old Jun 13, 2005 | 07:25 AM
DreamCatcher's Avatar
I also have water in my hatch....I'm buying new seals all around....
Old Jun 13, 2005 | 07:55 AM
Los.'s Avatar
Default Re: It RAINED and My car is leaking! (DreamCatcher)
same here
Old Jun 13, 2005 | 08:10 AM
silver88crxsi's Avatar
Default Re: It RAINED and My car is leaking! (crxkid88Sir)
same thing hapend here. i washed my car and looked inside and could see water. Pissed me off
Old Jun 13, 2005 | 08:11 AM
CRX Toad's Avatar
Default Re: It RAINED and My car is leaking! (silver88crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver88crxsi &raquo;</TD></TR><TR><TD CLASS="quote">same thing hapend here. i washed my car and looked inside and could see water. Pissed me off</TD></TR></TABLE> Why would it **** you off 2 birds with one stone clean the inside and outside all at once...it is a revolutionary car, buy today!
Old Jun 13, 2005 | 08:19 AM
tallguy's Avatar
Default Re: It RAINED and My car is leaking! (CRX Toad)
I have to dry out the lake in my crx every time it rains. I found out that it was the seal behind the rear brake light. but no rust..
Old Jun 13, 2005 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote"> Why would it **** you off 2 birds with one stone clean the inside and outside all at once...it is a revolutionary car, buy today! </TD></TR></TABLE>
haha wise ***. No it was leaking right on my speaker cover from the hatch and i was thinkin **** somethings goin to get fucked up . But luckily it didnt.
Old Jun 13, 2005 | 10:53 AM
88 civic ef's Avatar
yea my hatch leaks water from the front driver speaker and rear hatch. HOW DO I FIX IT &gt;&gt;?????
Old Jun 13, 2005 | 12:06 PM
Flamegurl's Avatar
I had the problem in my trunk.
One of my friends just took a screwdriver and a hammer, right in the center of the trunk is a little ring. He jammed that screwdriver ones with a hammer. No more water in the trunk!
Old Jun 13, 2005 | 12:37 PM
Default Re: (Flamegurl)
maybe ill check one at a time to see where the problem is. the good part is only the front part leaks. nothing gets wet in the back, only where the passenger seat used to be and the driversider's side where the carpet used to be. the driver's seat dont even get wet. also, my battery died again. forgot to disconnect the one thats not red (negative terminal?) must be faulty wiring. could it be that the red terminal is loose? a new terminal should fix it rite? so much trouble! i new i should have bought a RSX or STi...
Old Jun 13, 2005 | 03:12 PM
crx-treme's Avatar
Default Re: (Wasabithegosu)
my crx leaks through the driver side hatch piston, where it connects to the hatch. cant figure out where its coming from....ive heard the rear sprayer nozzle could be the culprit,,,idk
check this out
http://www.geocities.com/Athen...q.txt
(its for crxs)
Old Jun 13, 2005 | 06:38 PM
civiccrx21's Avatar
Default Re: (crx-treme)
I have a similar problem where it leaks from the shocks where it connects to the hatch drip by drip? Ive tried to silcone **** left and right but still no luck , finally I drilled lil drain holes in my hatch (CRX) and painted them , wooohooo hurricane season is here
Old Jun 14, 2005 | 12:37 AM
crx-treme's Avatar
Default Re: (civiccrx21)
little drain holes?! where? did it work. i hate the drip by drip leak as it drips right on the rear speaker cover.....
Old Jun 14, 2005 | 12:49 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">little drain holes?! where? did it work. i hate the drip by drip leak as it drips right on the rear speaker cover.....</TD></TR></TABLE>
Just drill some holes in the spare tire well..And paint where ever you drill to prevent rust..
Old Jun 14, 2005 | 04:46 AM
slywfbpsi's Avatar
Default Re: (Mr.speaker)
mine drips right over the driver seat. With black cloth seat you can't tell they are wet until you sit in them then you look like you've peed down the right side of you leg when you get out.
Old Jun 16, 2005 | 02:30 PM
Default Re: (slywfbpsi)
wow that sucks. im lucky mine dont do that. i thought i had a leak problem. its even worse coz i took out the carpeting. well i guess its better in a way. but still, its the fact that my car leaks. ahhhh. im gona have to silicone the windshield. speaking of rain, its about to rain again....
Old Jun 16, 2005 | 02:45 PM
Agent STFU's Avatar
Mine leaked HORRIBLY last two weeks - but then I found a regulator and put the window back in and no more problem
Old Jun 16, 2005 | 11:11 PM
i have a 88 civic hatchback and everytime i wash my car both speaker pods in the front is always wet. i took out the speaker pod to see where it is coming from and it is coming from the top near the windshield. Does anyone know where in the windshield of can i put something on the speaker ipod to prevent it from leaking cause i brought new speakers and they are getting wet too
Old Jun 17, 2005 | 05:31 AM
K-Drum's Avatar
they have this stuff that puts the moisture in the seals, I applied that stuff to the seals in my car ( hatch & doors) and it stoped leaking as much... the Hatch leak is gone.
might be worth a Try... my buddy said that Food Grade veg oil works that same way.
Old Jun 17, 2005 | 10:29 AM
Default Re: (K-Drum)
food grade veg oil? so wuts this other stuff you used?
Old Jun 20, 2005 | 06:36 AM
K-Drum's Avatar
it's like a silicone spray, I got it at an autoparts store, but I'm told honda has something equivalent.
if you go to the parts counter of any auto parts store ask for something to put on your old seals to make them seal again... I'll try to find the name of the stuff.
