How To Tell which Tranny you have????
Old Jun 13, 2005 | 03:57 AM
90 Si Hatch's Avatar
Default How To Tell which Tranny you have????
hey whats up yall, well yesterday i picked up another 5-spd cable D-series tranny for my car and i just wanted to know how to tell which year it maybe came from and if its out of a STD, DX, HF, or Si. If some one would help me out with this it would be great. Thanks
Isaac
Old Jun 13, 2005 | 04:39 AM
Default Re: How To Tell which Tranny you have???? (90 Si Hatch)
bump
Old Jun 13, 2005 | 04:53 AM
crxnj's Avatar
It's not from a std since they are 4spd..
Isnt there any writing on it? And how many splines are on it?
Old Jun 13, 2005 | 05:11 AM
Default Re: How To Tell which Tranny you have???? (Mr.speaker)
well i found out what year it is, now all i need to know is what it is DX, HF, Si
Old Jun 13, 2005 | 05:49 AM
bump???
Old Jun 13, 2005 | 05:57 AM
crxnj's Avatar
Is there an ID # on it??
Old Jun 13, 2005 | 06:02 AM
where would it be at?
Old Jun 13, 2005 | 06:06 AM
boosted_hatch_216's Avatar
it should say like LM3 or something like that.
Old Jun 13, 2005 | 06:08 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 Si Hatch &raquo;</TD></TR><TR><TD CLASS="quote">where would it be at?</TD></TR></TABLE>
Its by the fill plug..
If its an 88 it has no markings at all..
Old Jun 13, 2005 | 08:32 AM
well i think its an 89 cause i red on this other post something about if it has 0 groves on the input shaft its an 88 and if there is 1 grove on the input shaft its and 89 and 2 groves its an 90-91, if that right?
Old Jun 13, 2005 | 10:28 AM
HumanResource's Avatar
http://crx.honda-perf.org/
Go to CRX MATH then find your cruising speeds
Old Jun 15, 2005 | 09:11 AM
Default Re: How To Tell which Tranny you have???? (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
If its an 88 it has no markings at all..</TD></TR></TABLE>
ok well there is the fill plug that is under the starter, then there is the check level plug, and then there is the drain plug so which is it??? I'm sorry to be so dumb
Old Jun 15, 2005 | 12:13 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://norcalcrx.org/nikita/CRX/tranny1.jpg
http://norcalcrx.org/nikita/CRX/tranny2.jpg
If the tranny is out,The method on the first page worked for me..
Clamp a small pair of vise grips to the input shaft and make a mark
on the differental..
Cut and pasted:
"check where the axles goes in thru the pass side
by the hole there a stamp...
like a circle.. on the top side it says PL3
on the bottom it will say
Si = 1000, 3000, 9000
DX or lower model = A100 , A300, A900, A000"
Old Jun 16, 2005 | 01:57 PM
Default Re: How To Tell which Tranny you have???? (88DXCRX)
that is flipin sweet
Old Jun 17, 2005 | 10:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">http://norcalcrx.org/nikita/CRX/tranny1.jpg
Cut and pasted:
DX or lower model = A100 , A300, A900, A000"</TD></TR></TABLE>
well the tranny is out so how do i put it in 1st gear???
Old Jun 17, 2005 | 10:52 AM
88DXCRX's Avatar
Just imagine how the shifter works,
Roll it to the left,When you push the shifter forward
it pulls on the rod.
So roll it left and pull out and that should be first..
Old Jun 17, 2005 | 12:45 PM
Ok great, Thanks man u've been a bunch of help ill let you know how it goes!!!
Old Jun 17, 2005 | 02:55 PM
Kwicko's Avatar
This might help, too:
http://www.d-series.org/forums...mbers
Short of cracking it open and counting teeth on the gearsets, or doing the "spin test" to see how many times the diff turns per 10 turns of the input shaft, it gets hard to really KNOW what the transmission is for sure. The "Axxx" and "Bxxx" seem to be pretty solid indicators, though... but for every "rule", it seems there's at least one exception.
Hope you find out for sure soon, and hope it's what you wanted.
Mike
Old Jun 18, 2005 | 05:12 AM
Default Re: How To Tell which Tranny you have???? (Kwicko)
well i got the tranny for free and it also came with a short shifter, so i'm not really out of anything
Braco11
Jan 18, 2010 10:13 AM
BoostdRex
Aug 3, 2007 05:06 PM
hedtrip
Mar 29, 2006 04:15 PM
streetlegal gocart
30
Aug 21, 2003 08:11 AM
H.crx-si
May 14, 2003 07:06 AM
