This pin is driving me insane....
Old Jun 12, 2005 | 09:11 PM
ScootinIntegra's Avatar
Default This pin is driving me insane....
I've searched for hours on HT and tried everything I've seen. I still can't get the bitch pin out of the tranny. I've used a torch, lube, and wailed away with a hammer and 8mm punch. I'm in the process of looking for an 8.5mm, since apparently that's what you need. Any other suggestions at all?
Old Jun 12, 2005 | 09:12 PM
HARI.'s Avatar
Default Re: This pin is driving me insane.... (ScootinIntegra)
just keep pounding at it with the 8mm punch. they don't call it bitch pin for nothing
Old Jun 12, 2005 | 09:14 PM
Default Re: This pin is driving me insane.... (DA9-hari)
heh, that's what i was afraid of. So if I get this thing out, how hard is it to get back in?
Old Jun 12, 2005 | 09:25 PM
13sechatch's Avatar
its a piece of cake to get in the tricky part is getting it out
Old Jun 12, 2005 | 09:53 PM
importdude2000's Avatar
keep pounding it
i noticed that it was easier to take the tranny out with it first
then u have more room and hit stright..
took about 15mins of 3 people smacking it
then it started going out!
Old Jun 13, 2005 | 01:30 AM
Default Re: (importdude2000)
The tranny is already out of the car, we pulled the engine with the linkage attached.
The hard part is getting it back in there.
Old Jun 13, 2005 | 05:06 AM
projectTeG's Avatar
which side are you hitting it out from???....also ive noticed if that they get but in backwards, they are a real pain in the *** to get out...., but yea just keep pounding at it.
Old Jun 13, 2005 | 08:41 PM
Default Re: (projectTeG)
Don't think it's possible to get at it from the top side....
Old Jun 13, 2005 | 08:50 PM
solareclipseauto's Avatar
Default Re: (ScootinIntegra)
give it some good strong hits
Old Jun 13, 2005 | 08:56 PM
Kendall's Avatar
Put the motor back in with the linkage still attached. The last 4 swaps I've done I haven't messed with a single bitch pin and my life has been much less stressful.
Old Jun 13, 2005 | 08:57 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScootinIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Don't think it's possible to get at it from the top side....</TD></TR></TABLE>
yeah it is. just pound the **** out of it with *****
Old Jun 13, 2005 | 10:45 PM
AlphaQup's Avatar
Default Re: (DA9-hari)
Jack up your car higher with a hydrolic jack if you don't already have one. You need some swingin action to get that bitch out. Watch your fingers holding the punch though haha. Good luck
Old Jun 14, 2005 | 11:04 AM
projectTeG's Avatar
oops was vague....i meant if someone had installed it when the previously pounded side went in first it would be hard to get back out since it it was pounded and expanded it would fit tighter
Old Jun 14, 2005 | 11:39 PM
I think that's what happened...
Anyway, I just repositioned the engine and dropped it back in with the linkage attached, just like last time. Thanks!
Old Jun 15, 2005 | 12:50 AM
XDEep's Avatar
mine eventually came out. but i wonder, does all that whacking affect the shift rod? i forget how it connects inside..
Old Jun 15, 2005 | 07:11 AM
dwnthehatch's Avatar
The bolts that hold your ac compressor is an exact fit. Use it as a punch. It's ghetto, but works every time.
kpop
Apr 8, 2006 07:13 AM
FormulaGSR
Jul 12, 2005 08:12 PM
Tyson
Apr 22, 2004 06:20 PM
SL2-to-GSR
Apr 21, 2003 11:48 AM
