just need some insight.
I'm thinking about purchasing a pair of skunk2 stage2 cams with the upgraded valvetrain (must do). what i want to know is will it yield any good power???.
my car is a 94 b18c1 acura integra gs-r
mods:
: AEm short ram intake
:skunk2 intake manifold
:TEst pipe, removed muffler
: skunk2 p28 ecu vtec4800-redline9000
:LS transmission(will be gone soon for a gs-r tranny)
:fluidyne radiator
:clutchmasters stage 3 clutch.
:removed A/C
;REmoved power steering.
:ground control cloilovers
if it matters "new internals".
ANY HELP WOULD BE APPRECIATED
mods:
:fluidyne radiator
:removed A/C
maybe im wrong but im pretty confident that intake manifold isnt helping with out those cams. and your catless exhaust probably just smells. i dont know, do you drive it everyday?
Getting some ctr/itr pistons or some higher compression aftermarkets with those stage2 cams would probably be pretty good.
I'm sure you would yield more then you have with the cams but a bump up for compression should be even better.
yea i will buy some other pistons as soon as i get more money. but for right now i want to know if it is okay to drive it with jsut those and with the mods i have.
i went with a jdm 4-1 , but you will also have to get a 2.5" collector gasket and flange if you want it to fit right along with a new test pipe or hi-flo cat, i went with the hi-flo cat, im satisfied with the power
