value train conversion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbj728 »</TD></TR><TR><TD CLASS="quote">I have a 96 Honda Civic with a D16Y7 engine. I want to change the valuetrain to a D16Y8 want do I just need the valuetrain or more things and is it worth it.</TD></TR></TABLE>
Unless you're going to grab a VTEC solenoid and shove it in the side, it'll be hard to make use of the VTEC valvetrain
The head swap would be easiest (the "mini-me"), although easy, in this case, is relative, as many noobies try the mini-me and end up messing things up. However, our very own moderator "BauleyCivic" has a fantastic write-up on how to do it successfully. I suggest you look into that before making any final decisions as to where your money will be spent
.The head swap would be easiest (the "mini-me"), although easy, in this case, is relative, as many noobies try the mini-me and end up messing things up. However, our very own moderator "BauleyCivic" has a fantastic write-up on how to do it successfully. I suggest you look into that before making any final decisions as to where your money will be spent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
hahaha so true.
https://honda-tech.com/zerothread?id=635580
.</TD></TR></TABLE>
hahaha so true.
Valuetrain, u dont need no stinking valuetrain
thaiboiz
Dec 23, 2006 10:14 AM
