another happy Seafoam customer today another detailed write up inside.
Old Jun 12, 2005 | 04:05 PM
Ebony and Ivory's Avatar
Default another happy Seafoam customer today another detailed write up inside.
I just Seafoamed my 94 LS with 140,000 miles today. Man was it ever a lot of smoke. It smoked like a chimney for a bout a mile, then it stopped. I honestly can feel better accel, my exhaust is louder and doesnt sound boggy anymore, I also, my idle is smooth, and when I start the car no hesitation.
heres another write up on it.
Start car, let the car idle until it reaches normal idle temp (temp gauge 1/4 way up)
using pliers, disconnect the clip that holds the 2 hoses(Brake booster line located on firewall to the drivers side) together, pull it apart, you car is going to go into a higher idle, high low high low.
measure out 1/3 of a pint of SEAFOAM (about 6 oz.) into a measuring cup. using a funnel pour the contents from the measuring cup into the line, SLOWLY, to much will shut the car down. watch your baby smoke.
As soon as its all in the hose, shut the car down. let your car sit off for 10-15 mins(the bottle says 5 but longer will yield better results). reconnect your hoses and turn your car on and your going to have to keep pressing the gas to keep it from shuting down.
Hit the road and slam all of your gears at least to 6K rpm, (I did redline), while you fill the road behind you looking like you just performed a burnout from hell. when you see all the smoke has come from your car, drive normally for about 10 mins, ( I did 10 miles). she gonna run like new. no problem with plugs or anything. thats it your done.
If you want to do your crankcase too, measure out 1/2 pint (8 oz). pour it into your crankcase when your car is off. drive it about 10 miles, take her home and immediately change the oil and filter. I have smoother shifts now.
Hope this helps you guys, I know theres like 5 write ups on this, but I had to add a new one.
Old Jun 12, 2005 | 04:12 PM
Danziver's Avatar
Default Re: another happy Seafoam customer today another detailed write up inside. (The Peezy Fo Sheezy)
Nice, i will be seafoaming my 175k mile teg soon.
Old Jun 12, 2005 | 04:37 PM
Contender25
Guest
Posts: n/a
Let me know how that goes, cause i got 175k myself.
Old Jun 12, 2005 | 06:02 PM
axi0m's Avatar
Default Re: (Contender25)
I got ~150k and I think I'll be doing the same thing around the time of my next oil change.
I assume this stuff does for your car the equivalent of what chugging a bottle of exlax would do to your digestive system eh?
Where can I get a hold of this stuff by the way?
Old Jun 12, 2005 | 06:33 PM
Contender25
Guest
Posts: n/a
I saw in another thread, you can get it at napa, am i correct?, because i wasn't too sure.
Old Jun 12, 2005 | 07:19 PM
THALADOR's Avatar
yeah you can get it at napa...ill vouch for seafoam...worked for me.....
Old Jun 12, 2005 | 07:41 PM
yrethguad's Avatar
I can't imagine how much mine will smoke...
Old Jun 12, 2005 | 07:42 PM
DAguyLS's Avatar
FYI - Seafoam = mineral spirits
and to tell you the truth steam through your throttle body works better at cleaning carbon deposits
Old Jun 12, 2005 | 09:29 PM
numbnuts22715's Avatar
will it still help if ive only got like 70k?
I figure I might as well do it if it'll help.
Old Jun 18, 2005 | 07:26 PM
phateless's Avatar
is this procedure a normal maintenance kind of thing, or is it only for circumstances where the car's not running real well?
Old Jun 18, 2005 | 07:34 PM
5spdIntegra's Avatar
Default Re: another happy Seafoam customer today another detailed write up inside. (The Peezy Fo Sheezy Neez
I have a great write up that should clear some things up. Check my signature for the link.
Old Jun 26, 2005 | 04:05 PM
97dxnut's Avatar
Sorry if i'm hijacking, but i have a 98 accord with 93k miles on it. Due to a combination of reasons i havn't changed the oil in over a year. Put about 15k miles on it since then. Would seafoaming the engine before changing the oil help it? Thanks.
Old Jun 26, 2005 | 04:36 PM
vtecmissle's Avatar
must be alot of new bandwagoneers on here. Maybe you should read his post. How the hell does this affect how his car shifts?
Old Jun 26, 2005 | 07:11 PM
Spectrum24x's Avatar
Default Re: (vtecmissle)
anyone see the thread of the guy that thought the seafoam killed his car?
it acted possesed and wouldnt shut off when he took the key out... there was smoke coming from the intake..
kinda funny.
I'll try to find the thread.
Old Jun 26, 2005 | 07:13 PM
Default Re: (Spectrum24x)
Here it is..
https://honda-tech.com/zerothread?id=1155239
Old Jun 26, 2005 | 09:53 PM
RuskeR's Avatar
I'll eventually do this to my teg. I've got about 88k on the 00GSR. She is getting old.
Old Jun 27, 2005 | 03:06 AM
RicharDC4's Avatar
Default Re: another happy Seafoam customer today another detailed write up inside. (Makaveli the Don Spirit)
i always wondered, will seafoam help improve gas milage by any chance? because im getting the worst milage ever. 230 average on a full tank.
i really want to seafoam my teg too but my neighbors might complain about the smoke since i live in a small court...
Old Jun 27, 2005 | 06:22 AM
IntEGNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxnut &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if i'm hijacking, but i have a 98 accord with 93k miles on it. Due to a combination of reasons i havn't changed the oil in over a year. Put about 15k miles on it since then. Would seafoaming the engine before changing the oil help it? Thanks.</TD></TR></TABLE>
nice way to drive your car into the ground. heheh
yes, seafoam can help a little to clean your engine internals but it wont help any damage from running dirty oil.
Old Jun 27, 2005 | 06:55 AM
..::91TEG-G2::..'s Avatar
i heard that the carbon deposits in older engines could be keeping the compression up in your cylinders by cloging up "holes" that could lower your compression. which will result in your car actually loosing compression and performance/hp numbers..
ima do a search for that real quick but have any of you heard about this or experianced it in any way?
Old Jun 27, 2005 | 11:47 AM
97dxnut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">
yes, seafoam can help a little to clean your engine internals but it wont help any damage from running dirty oil.</TD></TR></TABLE>
Yea i know, no one to blame but myself. I just finished changing it. Came out pitch black (last year i put in the nice, golden-beer colored mobil 1 synthetic)
Old Jun 27, 2005 | 11:54 AM
no2unenolife's Avatar
seafoam is sweet, i just get paranoid because i don'tt wanna get pulled over
BigDaddyRich
Jan 11, 2012 08:11 AM
b18cisbetter
Dec 8, 2009 06:04 AM
TypeRKoncepts
Mar 4, 2005 04:24 PM
el arbi
Apr 30, 2003 08:29 PM
MintyDip
Jul 5, 2001 03:10 PM
