*Project* All Motor Ls/Vtec
Old Jun 12, 2005 | 03:41 PM
Ekay Jay's Avatar
Default *Project* All Motor Ls/Vtec
UPDATE on page, 2, 3
Well i finnaly started buying all my parts for my ls/vtec and decided i would take a bunch of pics of my project since there is alot of people on here doing ls/vtec swaps. I will have tons of updates and pics.
The setup:
B18a block
Pr3 pistons + new rings
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
acl main, rod, and thrust bearings
Bored .20 over + fresh hone
Shot peened rods
micropolish crank
balanced bottom end
B16a sir1 head(stock)
B16 ls1 cable tranny with 6 puck
Chipped p28- tunned with uberdata
And This what i have so far
My complete b16a engine
Head removed
Modified by JdM DA InTeGrA at 2:08 PM 7/23/2005
Modified by JdM DA InTeGrA at 6:46 PM 7/24/2005
Old Jun 12, 2005 | 03:44 PM
Ekay Jay's Avatar
Default Re: *Project* All Motor Ls/Vtec (JdM DA InTeGrA)
My new parts....
Golden eagle ls/vtec kit
ITR oil pump
Gsr water pump
Modified by JdM DA InTeGrA at 10:37 PM 7/22/2005
Old Jun 12, 2005 | 03:51 PM
onepoint6i's Avatar
good luck on the build...what cams, head work you going with?
Old Jun 12, 2005 | 03:53 PM
Ekay Jay's Avatar
Default Re: *Project* All Motor Ls/Vtec (1.6i)
Its going to be a stock head. It pretty much a oem build. I might get some ctr or itr cams though.
Old Jun 12, 2005 | 04:13 PM
The Destroyer's Avatar
Subscribing, I love **** like this.
Old Jun 12, 2005 | 05:45 PM
Yambor's Avatar
Default Re: *Project* All Motor Ls/Vtec (Vtaaak y0)
you have some good plans.. You do know that the itr oil pump is the same as the gsr and such right? just thought id let you know. Good luck on the build..
Old Jun 12, 2005 | 06:01 PM
Ekay Jay's Avatar
Default Re: *Project* All Motor Ls/Vtec (JH4DC4-2GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR &raquo;</TD></TR><TR><TD CLASS="quote">you have some good plans.. You do know that the itr oil pump is the same as the gsr and such right? just thought id let you know. Good luck on the build..</TD></TR></TABLE>
Yea i know they are the same, i just came across this new itr oil pump for $100 so i bought it. But a gsr will work just the same.
Old Jun 12, 2005 | 06:10 PM
Professor15's Avatar
Get a valve job to the head, with some buddy club 3+ cams and your good.
Old Jun 12, 2005 | 07:09 PM
Ekay Jay's Avatar
Default Re: (drchulo)
For now its gonna be stock. but in the future im gonna go with some m22's.
Old Jun 12, 2005 | 07:25 PM
Lil Corb's Avatar
do you need to get a gsr belt tensioner if you use a gsr timing belt? or would the b18a work fine?. also would a b18a cable block work with a b16a2 hydro tranny and b16a2 head?
Old Jun 12, 2005 | 08:50 PM
Combustion Contraption's Avatar
The stock tensioner from the b18a will work fine. But its not terribly expensive to just buy a new one.
If you can all afford it, get some headwork done by one of the big 3.
RLZ, Portflow or Alaniz.
Old Jun 12, 2005 | 10:38 PM
Zero4Racing's Avatar
Default Re: (LsVtec92Hatch)
good luck on the build, and to answer your question "lil corb", you will be fine using the the B16a2 tranny and head on a B18a 90-93 style LS block. take it easy... mike
Old Jun 13, 2005 | 05:40 AM
Lil Corb's Avatar
Default Re: (Zero4Racing)
thanks guys
Old Jun 13, 2005 | 12:28 PM
Ekay Jay's Avatar
Default Re: (Lil Corb)
Guys if i bought these pistons... http://cgi.ebay.com/ebaymotors...=WDVW , What would that put my CP at?
Old Jun 13, 2005 | 04:05 PM
Ekay Jay's Avatar
Default Re: (JdM DA InTeGrA)
ttt
Old Jun 13, 2005 | 04:18 PM
HondaCivicSiR1's Avatar
here check out the this http://bojangs.com/calculator
Old Jun 16, 2005 | 05:27 PM
kenny24's Avatar
its gonna pull nice!! i just got mine running going 2 nites ago and i smoked my frends supercharged gsr in a ef. where did u get ur ARP rob bolts??????
Old Jun 16, 2005 | 05:44 PM
philafelman's Avatar
Default Re: *Project* All Motor Ls/Vtec (kenny24)
where did you find oem pistons that are 0.20 oversized (in or mm)?
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Guys if i bought these pistons... http://cgi.ebay.com/ebaymotors...=WDVW , What would that put my CP at?</TD></TR></TABLE>
pretty much the same as the pr3's, ~11.5:1
Old Jun 16, 2005 | 07:35 PM
Archidictus's Avatar
Unceasing Measure
What intake manifold are you looking at?
Old Jun 16, 2005 | 07:47 PM
Ekay Jay's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">What intake manifold are you looking at?</TD></TR></TABLE>
As of now im gonna be usning the stock b16 mani. But sice i havnt really feedback about the skun2 pro i think im gonna get it and see if its any good.
Old Jun 16, 2005 | 07:49 PM
Ekay Jay's Avatar
Default Re: *Project* All Motor Ls/Vtec (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">where did you find oem pistons that are 0.20 oversized (in or mm)?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=598414
Old Jun 16, 2005 | 08:00 PM
mportbusta's Avatar
Nice man!!!!
Old Jun 16, 2005 | 08:02 PM
Ekay Jay's Avatar
Default Re: *Project* All Motor Ls/Vtec (mportbusta)
My ls will be coming out july 8th and 9th. Then the block and crank will go to the machine shop and i can do a wire tuck.
Old Jun 16, 2005 | 09:54 PM
honestly, just get a type r intake manifold, you can usually find those used for pretty cheap and they make good power for the 1.8 bottom end you're running. just trying to save you a couple bucks. mike
