Aftermarket steering wheels, how did you mount your horn?
Old Jun 12, 2005 | 03:16 PM
Junkyard2000's Avatar
Default Aftermarket steering wheels, how did you mount your horn?
Im trying to figure out how to mount the horn to stay in place. I have a mugen wheel, sparco hub, and the quick release.
The quick release came with these, what are these used for?
Heres the horn and it also came with a ring
This came with the sparco hub
Old Jun 12, 2005 | 03:22 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Aftermarket steering wheels, how did you mount your horn? (Junkyard2000)
circle clip should fit inside of the 4 prongs on the horn, and it should snap right into the steering wheel
Old Jun 12, 2005 | 04:08 PM
Default Re: Aftermarket steering wheels, how did you mount your horn? (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">circle clip should fit inside of the 4 prongs on the horn, and it should snap right into the steering wheel</TD></TR></TABLE>
youre talking about the ring next to the horn in the pic? I tried that and it barely makes em stick out any further. Maybe ill just tape it or something
Old Jun 12, 2005 | 07:05 PM
chameleon's Avatar
basically stick the horn buttom in that round thing and then from the back stick the C clip behind the horn, it makes those plasctic pieces that stick out the back of the horn buttom get wider and basically hold the horn in place.
Old Jun 12, 2005 | 07:28 PM
Default Re: Aftermarket steering wheels, how did you mount your horn? (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">basically stick the horn buttom in that round thing and then from the back stick the C clip behind the horn, it makes those plasctic pieces that stick out the back of the horn buttom get wider and basically hold the horn in place.</TD></TR></TABLE>
yea i tried that. The ring is too big. Maybe cause its a sparco hub ring? Im just gonna elmers glue the horn to the wheel or just tape it from the back
Old Jun 12, 2005 | 09:58 PM
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">
yea i tried that. The ring is too big. Maybe cause its a sparco hub ring? Im just gonna elmers glue the horn to the wheel or just tape it from the back</TD></TR></TABLE>
take the ring from the last pic and put it between the wheel and the part of the quick release that removes when the wheel removes... then take the clip that is in the second pic and fit it into the grooves of the button..... viola it will snap right into the hole
Old Jun 12, 2005 | 10:12 PM
FalkenSiR's Avatar
Default Re: Aftermarket steering wheels, how did you mount your horn? (warwagon)
I wired it to my red nos buttoms. Works awesome.
Old Jun 12, 2005 | 10:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">
take the ring from the last pic and put it between the wheel and the part of the quick release that removes when the wheel removes... then take the clip that is in the second pic and fit it into the grooves of the button..... viola it will snap right into the hole</TD></TR></TABLE>
like this
But look how much space is left. I think the outer ring is too big. Maybe I have the wrong size.
Synergy001
Oct 27, 2006 10:35 PM
Mr.OB*GYN_Rhett
Sep 25, 2006 01:07 PM
FATBOY SPEC
Sep 13, 2006 06:25 PM
EKB18BPR3
Aug 24, 2006 09:55 AM
