Spark Plug ?'s
Old Jun 12, 2005 | 03:14 PM
97akwerd's Avatar
Default Spark Plug ?'s
I changed my spark plugs with NGK Vpowers. Paid about 8.00 for them.
After I put them in I noticed bad gas milage, what could be the problem? I'm at 200 miles at a quarter tank.
Old Jun 12, 2005 | 03:52 PM
Accord95Lxxx's Avatar
are those the ones with dual electrodes?
Old Jun 12, 2005 | 04:58 PM
fw190bvi's Avatar
Default Re: (Accord95Lxxx)
oem NGK Coppers.....F's only like single electrode...
Old Jun 12, 2005 | 05:17 PM
subgeniusdude's Avatar
Default Re: Spark Plug ?'s (97akwerd)
Just installed NGK Irridium IX plugs yesterday...$32 for the set at Advance Auto Parts,so far I like them....trying to get better MPG since I drive 50 miles/day to work.
Old Jun 12, 2005 | 05:26 PM
fw190bvi's Avatar
Default Re: Spark Plug ?'s (subgeniusdude)
they wont do anything......having 4 electrodes is just dumb.....theres a good article on spark plugs in last months issue of GRM
Old Jun 16, 2005 | 02:58 PM
Default Re: Spark Plug ?'s (fw190bvi)
No,these dont have the four electrodes...the tips are irridium which is supposed to be more durable than platinum and copper and they're supposed the give a couple more hp.I haven't noticed much difference though.
Glenn
Old Jun 18, 2005 | 07:28 AM
Duane_in_Japan's Avatar
Are you sure you are not just trying out your new added HP and getting really bad gas milage, you have to compare apples to apples, you are going to have to drive like grandma to get an accurate milage test done, just drive 500 miles on the highway tonight and see what you get, oh and by the way, stick to the speed limit too. Good luck. Iridium tips only last longer, different heat ranges gives the extra HP as does different types of plugs, all debatable.
Duane in Japan
Old Jun 18, 2005 | 07:51 AM
twkdCD595's Avatar
what heat range... is it a hotter replacement plug you put in?
Old Jun 18, 2005 | 11:11 AM
Muffler Bearing's Avatar
I have Denso Iridiums and I love them, totally worth the $40.
Old Jun 19, 2005 | 09:57 PM
goowakjai
Guest
Posts: n/a
Default Re: (Muffler Bearing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muffler Bearing &raquo;</TD></TR><TR><TD CLASS="quote">I have Denso Iridiums and I love them, totally worth the $40.</TD></TR></TABLE>
wow, 40 bucks...and i thought i was big spender with my 2 dollar each plugs(NGK coppers! )
R00teg
Jun 12, 2004 12:38 AM
CaptivaBlue
May 28, 2004 07:15 PM
RedGSR
Apr 24, 2004 10:36 AM
98cwitr
Sep 29, 2003 07:23 AM
intekragsr
May 9, 2002 09:06 PM
