will gen 2 or 3 hubcaps fit on my gen 2 blades?
buhahahahahahahahaha!!!!!..................No it will not fit.
The rims don't have the proper lip that black steel rims that comes with hubcaps have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">Look how the wheels are in opposite directions, time to rotate.</TD></TR></TABLE>
Or maybe his tires are still in the right direction???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5spdIntegra »</TD></TR><TR><TD CLASS="quote">
Or maybe his tires are still in the right direction???</TD></TR></TABLE>
Either way he needs to switch sides with them
yes, the larger center caps will fit. even the little "Si" center caps will fit in the middle and stick out a little to about the same length as your lugnuts.
you can even get the correct sized center caps from an accord and be mad jdm with an H on each wheel.
slikflip
Jul 13, 2006 07:32 PM
