CTR cams or skunk2 stage 1?
Old Jun 12, 2005 | 09:38 AM
SD1222's Avatar
Default CTR cams or skunk2 stage 1?
Which camshaft would u guys picked out of the 2? ctr or skunk2 stage 1? This is going in a 94 civic hatchback with a gsr motor, 4-1 header, blox intake manifold, full catback exhaust. Would i make more power with the skunk2 stage 1 or the ctr? Any help would be great!!
Old Jun 12, 2005 | 10:14 AM
ImportechPerformance's Avatar
Default Re: CTR cams or skunk2 stage 1? (jdm_spoonEG)
Youll make more power with the stages ones...but not that the ctr are a bad choice. This is not from first hand expierence but just things and dyno plots ive seen on HT.
Old Jun 12, 2005 | 10:29 AM
Yambor's Avatar
Default Re: CTR cams or skunk2 stage 1? (ImportechPerformance)
- STOCK CTR and 2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
Skunk2 Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.8 mm, duration 249 @1mm
see for yourself
Old Jun 12, 2005 | 10:30 AM
hatch34's Avatar
if your goin to spend the money then get a bigger cam then just the Stg1's
Old Jun 12, 2005 | 01:47 PM
G U E C O's Avatar
i head stock bc spec 3 are good on a stock gsr engine
easycheese
Feb 23, 2008 11:06 AM
Fresno_NSX
Mar 28, 2005 01:24 PM
JdmFront619
Jan 25, 2004 05:58 PM
lakerschamp2000
19
Jun 30, 2003 01:49 AM
justBLZE
Jun 18, 2003 04:08 PM
