will my 94 accord ex ever handle like my roommates 94 prelude si?
i've been thinking about this for a long time. how much do i have to spend and what do i have to do to get comparable handling? will it ever happen? am i better off using my car as a downpayment on a prelude instead? i've been thinking about dropping it 1.5in with the tein h-tech springs, maybe a strut bar up top, maybe a sway bar in the rear, and then possibly some 16s. right now my car is all stock with 205/60/15 tires. will the drop and strut bar alone be enough? i took a ride in my roommate's car yesterday and it handled so well stock, i got depressed about my car. originally i chose my car over the prelude because you can't fit a mtn bike in the trunk of a prelude. should i give up and get a gsr or something?
you can make it handle better than a stock 'lude...but it depends how much money you are willing to spend...shocks/springs/bushings/front and rear strut bars, rear sway bars...there are so many options
better, with similar setups? really? that would be awesome but why is that? they both have the double wishbone suspension, but i thought the prelude's was more sophisticated...
I love my accord man! Once you install some springs/shocks or go with a coilover kit like I did, you'll def. appreciate your car! I also went and did front and rear bushings, f&r top strut mount braces, and camber kit. I think mine handles a little better than a stock lude!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote">better, with similar setups? really? that would be awesome but why is that? they both have the double wishbone suspension, but i thought the prelude's was more sophisticated...</TD></TR></TABLE>
only up front....rear is multilink mcpherson
as for price it all depends on how good you want it to handle? its not going to take much to upgrade to something that is equal to a ludes stock setup! i would say a little under a thousand if you had someone install coilovers or springs and if it is older some new shocks/struts but alot cheaper if you do it yourself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote">yea no kidding! how much did all that run you installed?</TD></TR></TABLE>
FREEEEEEEEEEEEEE to install.....If you have brains anyone can do it
As far as the rest of the pricing, about 1500 for everything.
I am running H&R sport springs, KYB AGX shocks, Front upper, rear upper and rear lower strut bar and a rear ST Sway bar. She rides on rails but is still comfortable. I still have stock wheels and I put my boys civic whos lowered like 3inches to shame when it comes to turns.
2000Accord5sp
Sep 27, 2002 03:45 PM
compared to most others on th e market
