busting a CV joint in my b16a swapped hatch
Old Jun 12, 2005 | 01:18 AM
Sound Streamin''s Avatar
Default busting a CV joint in my b16a swapped hatch
The first axles I used were some crap Felpro OEM replacment axles. The passenger side inner CV joint went after a few months. So I bought some Avid axles that are supposed to handle 250whp. After about 2 months the same CV joint has broken again. I know for a fact that Im not making close to 250whp (b16 with bolt ons) so I don't think the axles were over-powered.
I'm just trying to figure out what in the heck would be causing the joint to break. I have JimFab lower engine mounts, but the upper mounts are stock. The car is also lowered on Omnipowers.
Old Jun 12, 2005 | 10:22 AM
anyone?
Old Jun 12, 2005 | 11:04 AM
96CivicBoostCoupe's Avatar
Default Re: (Sound Streamin')
you might have to try to mix and match differnt honda cv axels, the axels need to have the right angles and lengths or they will cause them to snap, i had this problem on a 97 hb with an h22 swap and went through 4 pairs before i figured it out. chrck out hasport.com, a little expensive but the make the right axels for swaps and they are pretty durable, or you can go to pepboys and buy axels they have a lifetime warranty, so at least if you snap em, you get new ones for free
Old Jun 12, 2005 | 02:34 PM
I have a feeling it has to do with my rear mount. When I did the swap, they didnt send the proper mount. My buddy took the mount they sent and my stock mount and make a new one. Wouldn't be surprised if it was doing it.
Old Jun 15, 2005 | 01:56 PM
that may very well be the case, that would put the cv shafts in an akward angle cauing them to bust
EKJACE
May 22, 2011 09:56 AM
wannaBjdmca6
Suspension & Brakes
Oct 16, 2010 05:25 PM
HATCH22A
Jan 5, 2010 06:54 AM
hondah23eg
May 27, 2008 06:09 PM
G1 TEGGY
Aug 17, 2004 04:34 PM
