thermometer gauge not reading? why?
Bad grounds are usually the problem.
Have fun tracing all of them.
There's a simple trick. If you hook up the green/yellow wire from the sensor to a ground, and the temp gauge shoots up...you've got work to do on the grounds.
There are so many possibilities. Problems include:
1. Faulty sensor
2. Disconnected sensor
3. Faulty gauge
4. Wiring problems between the sensor and gauge
5. Fuse for gauges is blown
6. Bad ground
7. Wiring problem from battery
1. Faulty sensor
3. Faulty gauge
6. Bad ground
exactly which sensor are we talking about? because on my thermostat...there is no sensor unlike the obd1 thermostats.
