1996 accord lx automatic radiator
Old Jun 11, 2005 | 11:58 PM
dtrtw's Avatar
Default 1996 accord lx automatic radiator
Hi i wanted to know if there are transmission lines that goes to the radiator for a 1996 honda accord lx automatic and if anyone has pics of the installation please post them here thank you
Old Jun 12, 2005 | 12:07 AM
The_Todd's Avatar
Farts in the shower
Default Re: 1996 accord lx automatic radiator (dtrtw)
Yes there should be. Like in the 90-93 the coolant runs in a tank that is on the lower portion of the radiator...it helps cool the atf. Here is a picture to help:
You can barely see it but there are 2 fittings at the bottom of the radiator for the tranny fluid to run through, a feed line and a return line. I would suggest getting a repair manual as it will give you more detail and in depth on how to replace your radiator.
I can kind of do a step by step of replacing the radiator if you like.
Old Jun 12, 2005 | 07:46 AM
dtrtw's Avatar
Default Re: 1996 accord lx automatic radiator (.ken)
yes please if you can i can do radiators on manuel transmission cars i just havent done one with an automatic yet thanks
Old Jun 13, 2005 | 07:38 AM
ricebike's Avatar
well, u don't really need a writeup if u know how to do it w/ manual trans-equipped cars.
the only difference is the 2 trans hoses. undo the clamps from the trans housing or to the radiator, depending on space/accessability. just pull whole radiator out w/ hoses. aftermarket replacement radiator should have the nipples already there for swapping the hoses out.
i'd do a radiator flush w/ the old crappy radiator 1st, then do another w/ the new radiator. i guess u already know about the air bleed valve near the t-stat as well...
Old Jun 13, 2005 | 04:49 PM
dtrtw's Avatar
Default Re: (ricebike)
thanks i just needed to know if the lines were rubber or metal cause i didnt want to just pull it out and break the lines thanks guys do i have to clamo the hoses down? to prevent the atf from dripping?
Old Jun 13, 2005 | 10:41 PM
The_Todd's Avatar
Farts in the shower
Default Re: (dtrtw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtrtw &raquo;</TD></TR><TR><TD CLASS="quote">thanks i just needed to know if the lines were rubber or metal cause i didnt want to just pull it out and break the lines thanks guys do i have to clamo the hoses down? to prevent the atf from dripping?</TD></TR></TABLE>
The hoses are metal with a rubber outside...atf fluid will leak a little bit, just don't start the car with the hoses off .
You could disconnect the hoses where they attach at the AT and save yourself some clean up. There is one near the lower radiator hose where that connects to the t-stat. The other is near the front of the AT and is hard to miss.
GL
Old Jun 14, 2005 | 08:14 PM
dtrtw's Avatar
Default Re: (.ken)
where's the bleeder valve at?
Old Jun 16, 2005 | 04:21 PM
The_Todd's Avatar
Farts in the shower
Default Re: (dtrtw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtrtw &raquo;</TD></TR><TR><TD CLASS="quote">where's the bleeder valve at? </TD></TR></TABLE>
For the cooling system? Its right by the lower radiator hose near where it connects to the t-stat.
Old Jun 19, 2005 | 04:17 PM
dtrtw's Avatar
Default Re: (.ken)
thanks everyone got it done in like 5 hours i got to get some proper tools but it's done none the less thanks guys
Skibum007
May 25, 2007 01:18 PM
Rawr123
May 21, 2006 12:55 AM
GKIN
Aug 21, 2004 05:32 AM
mugwump
Jun 17, 2004 12:27 PM
